Thread: New Motor Install. Assuming there is no polarity?
    I am going to be installing this motor on my pool pump. I will be setting the motor to 110 volts as that is my supply voltage.
    I consulted the documentation I could find but didn't find the answer. With 110 I know there is the neutral and the hot. On most things you normally wire the hot to gold and the neutral to silver. However I've never wired a motor. Is there any "polarity?" Or can I attach it to either terminal?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    38,274
    Re: New Motor Install. Assuming there is no polarity?
    There is a polarity. There should be a wiring diagram on the motor.
