Thread: Switching to Z-Media in Sand Filter
    May 2016
    Toledo, OH
    81
    Good morning. I am planning on using a form of Z-Media this year once I open the pool. I see that you have to backwash the filter multiple times once adding the Z-Media to remove the dust, etc. My question is this....generally when I open the pool I have a bit of algae growth. If I am backwashing, won't this be drawing "dirty" water from the pool, causing difficulty to tell when the site glass is clear? One point I might add is that I do not currently have any sand in my filter. I removed it when I closed the pool last year.
    Thanks.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Switching to Z-Media in Sand Filter
    Welcome, Mark!
    Unless your water is a viscous sludge, I doubt you'll even see the tint through the sight glass.
    Before you go spending big bucks on sand replacements, take a minute to use the search box up in the right corner for Zeosand or Zeolite and see what others have experienced. Also worth a look: My findings on how not all sand is created equal
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I agree with Richard, do a little more research before you spend the bucks to Z-Media.
    Generally what people think of as "filter" problems end up being chemistry problems.
    Have you been following TFP guidelines? If not, as part of your research check,out Pool school and check out the FC/CYA relationship as well as information on stabilized chlorine vs non-stabilized.
    Welcome to TFP!
    Support the site
    May 2016
    Toledo, OH
    81
    Thanks guys
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In general we feel that sand almost never needs to be replaced and the few times it does is likely due to use of various magic in a bottle concoctions or Baqua-Slime when transitioning off of a baqua pool.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    I've read a lot of online complaints about Z-media...be cautious.
    I did have glass media in the last house/pool I owned and even though it's not as popular as sand in this
    forum it worked very well for me at the time.
    Dolphin E10 Cleaning Robot.
