Results 1 to 15 of 15
Thread: Bought house with green pool
    May 2016
    Marshfield WI
    12
    I just bought a house last fall, and the pool was green when I moved in. I winterized the pool green, after spending a lot of money trying to follow the pool store instructions. Now I'm opening my green pool.
    Please let me know if I'm going the right direction... I bought the pool testing kit recommended on this site and have the following
    CYA less than 20
    TA 110
    PH more than 8.2
    CH 125
    FC 0
    Based on pool math I just put 62 oz of pool stabilizer in a sock in the skimmer, with filter running.
    After 48 hrs I'll retest and get the pH to 7.7. After that I will attempt slamming with liquid chlorine by get FC up 16. Does this sound correct?
    I also bought some algaecide (dimethyl a benzyl ammonium chloride), what are the forums' thoughts on using the algaecide to speed up the process?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Bought house with green pool
    Welcome to TFP! Congrats on your new pool!
    You are on the right track. Nice work! Liquid chlorine or bleach, whichever is most convenient and best deal. LC is usually 10% and bleach is usually 8.25%. Skip the algaecide, contrary to the name, it doesn't kill algae. Many bottles actually admit that on the label. Lower your PH to 7.2 and then SLAM away. Scoop out as much junk as you can with a leaf rake. Brush the pool between testing and dosing more chlorine/bleach.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,386
    Hi! So nice to hear about the test kit! You will be so happy with it instead of the pool $tore!
    You are heading to a clear pool already. Good job!
    Kim
    May 2016
    Marshfield WI
    12
    I forgot to mention... my pool has a Salt Water Generator (Zodiac Clearwater). I don't know if it works. The water is still cold, so I wasn't planning on turning it on until summer and after I manually get the water clean with bleach/liquid chlorine. I noticed the recommended CYA for SWG pools is higher, but since I'm not using the the SWG is it still okay to slam the pool at a CYA of 40? I just want to make sure I don't damage the cell.
    14600 gallon above viynl ground pool, sand filter, and Zodiac Clearwater SWG.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You have it right! Leave the SWG off while you slam. It saves the cell for later. Go ahead and add the SWG to your signature..
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    DFW, TX
    24,450
    It is fine to SLAM at 40 with a SWG.
    May 2016
    Marshfield WI
    12
    First day of slamming my pool. Added the liquid chlorine last night. I have a question on the PoolMath though. My liquid chlorine is Sodium hypochlorite and I don't see that option in the FC options. Its the same as bleach, so I used the handy "Effects of adding chemicals" section at the bottom. Just wondering why Sodium hypo isn't an option in the FC section or if it is the same as a different option.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    For PoolMath just use the top line for bleach
    Add x of y% bleach. Jug size z.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Marshfield WI
    12
    Thanks... I must of missed that it said bleach right in the text, my mistake.
    So I did some testing during my slam:
    5/5/2016 6:30am
    FC 23
    CC 0.5
    5/5/2016 11:45am
    FC 21
    CC 0.5
    When I bought the house, the PVC pipe that connects multi-port value to the 8 prong thing in the sand was cracked and all of the sand was missing when I closed it last fall. I replaced the pvc pipe and put new filter sand in the filter. The starting pressure was at 15psi. After 3 days of running and cleaning the pumps skimmer basket, it is still at 15 psi. Any idea how fast the psi should be going up? I just want to make sure my filter is actually filtering. Is there anyway to know if the water is actually going through the sand and that the multi-valve isn't broken?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Does the gauge go to 0 when it's not running? Or a lower number in recirculate?
    You could also put some DE in there to see if that makes the pressure go up.
    May 2016
    Marshfield WI
    12
    Yes, the gauge goes to 0 when I turn the pump off. I will try the recirculate suggestion when I get home this evening. Thanks.
    On a side note... the pressure gauge is also brand new, since the old one was broken.
    Jul 2012
    Tallahassee, FL
    30,386
    Depending on the condition of the water it may be a LONG while before you need to backwash the filter.
    Kim
    May 2016
    Marshfield WI
    12
    Last night I checked the water and it was FC=17 and CC=1. This morning it was still FC=17 and CC=1. I'm assuming that means the algae is dead, but the water is still very green so it must not be filtered out yet. Last fall, based on pool store recommendations, I pumped the pool full of algae killer, power floc, and winterizing chemicals... maybe that killed all the algae. I checked the filter and in the filter position it is at 15psi, in the recirculate position it is at 13psi.
    My next plan of action is to try vacuuming the bottom of the pool through the filter, and then put a nylon sock over the skimmer basket. I know the power floc I used last year causes the algae to get heavier to sink to the bottom, is there any issues with putting that through my filter sand? Any other suggestions would be appreciated.
    May 2016
    Marshfield WI
    12
    Slamming the pool works... the pool water is clear and everything is working great.
    Aug 2010
    Dallas, TX
    4,052
    Good job!
