Thread: Liquidator installed next to heat pump
    Dec 2015
    Newington, Connecticut
    113
    Does anyone see any possible corrosion issues with placing the liquidator next to the heat pump? I would think the dilution would keep the fumes down.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Liquidator installed next to heat pump
    And if it is outside there is plenty of fresh air too.
    30,419
    The chlorine and water actually stay "layered" in the liquidator. The chlorine stays on the bottom and there is seldom any noticeable smell. That said, I would think a foot or more away would be smart even if not really needed.
    Dec 2015
    113
    Well, I got my answer to this question in a weird way. Went to turn the heater on and realized the hp power disconnect was disconnected when winterized. Just so happens I installed the liquidator right in front of it thinking I would just use the breaker in the panel. Well you live and learn, drain the liquidator, and move the liquidator. Now it's buried a foot in the ground with shorter tubing runs. Like this set up better.
