Results 1 to 9 of 9
Thread: Hot tub water turning translucent green after adding Shock
    Feb 2016
    Haslet/Texas
    2
    Hot tub water was clear then I added shock. It turned a clear green. What happened and how do I fix it?
    38,267
    Re: Hot tub water turning translucent green after adding Shock
    Can you be more specific about what chemical you added? "Shock" could mean just about anything.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    This is a classic example of metals in your water (iron or copper most likely), the question then becomes how did it get there. The answer is either in your fill water or through something you put in the tub. Many algaecides contain copper, so do many mineral systems, if you can tell us more about how you care for your tub we may be able to isolate how this likely happened.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP Yep, that real pretty bright green usually means metal in the water... Could you update your signature with your spa/equipment, it makes it easier to help
    also, is you fill from a well?
    Trouble Free Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    Emerald green would point to Copper. Sickly green is more likely Iron. Pool School - Metals in the Water and Metal Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    If you're on well (and I suppose even if not) Metal Gone spa metal sequestrant will clear iron tint for sure, with maintenance dosing of Metal Defender. (It what I use in the hot tub and my raw well water has 2 ppm iron. I also started using a Prefresh Filter last season, which helps to a degree IME.)
    But if you're not on well, and there's no metal in your source water, changing the water might be the solution.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Feb 2016
    Haslet/Texas
    2
    Thank you all so much for the quick responses!!! I will update my signature with our pool/spa specs and equipment too. The "shock" we used was not chlorine, it was specifically for hot tubs, but I don't have the name of it to memory. I believe it's just simply time to change the water out as it's new to us, our 1st tub to own, and we've had it going since March, and have used it often. So happy to have a positive feedback website to post & get info from. Thank you!!!
    Oct 2015
    Austin, TX
    83
    Is it "Spaguard Brominating Concentrate"? (Dichlor and bromide)
    I have a container of that and I think that's what has been turning my spa green too. Does it happen right away when you add the sanitizer? You can search my earlier thread on my green spa...
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If this is your first hot tub and you just bought it you may want to read How do I use Chlorine in my Spa (or pool)? and Used Spa
