Results 1 to 7 of 7
Thread: Hello, I'm Guy.
    Apr 2016
    Oceanside, Ca 92054
    3
    Hello, I'm Guy.
    We live in San Diego County. We are currently remodeling our irregular shape 15k gallon pool. After trying to save up enough money to re-plaster and new equipment. I tried getting bids from Full service pool contractors. They all were way out of our price range. So I am under taking the task as a project manager. I have learned so much from your site so iI decided to join in and seek your expert advice. Thanks for the opportunity.
    Jun 2014
    15,233
    Re: Hello, I'm Guy.
    Hello Guy and welcome to TFP! We hope your plaster project goes well. Keep us posted.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Hello, I'm Guy.
    Welcome, Guy!
    Do yourself a favor and be ready to protect that investment. Buy a proper test kit so it's waiting the day the pool is filled. You're the Project Manager, so startup is your problem. Do it right the first time.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Re: Hello, I'm Guy.
    SWEET! I am so glad to see this as I LOVE a redo!
    How about starting a thread in "under const." and share a picture of your current pool and tell us what you hope to do!
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello, I'm Guy.
    Welcome aboard Guy!
    Essential Links:
    Apr 2016
    Oceanside, Ca 92054
    3
    Re: Hello, I'm Guy.
    Thanks for the warm welcome.
    After removing the plaster from my pool I found this Crack is the side wall.(Sorry posted it sideways) My plan is to saw above the re-bar and to either side, then hammer chisel the rest of the way leaving the rebar in place. The crack is inline with a main drain and suction line replacement (upgrading to 3 inch) with 2 drains to avoid entrapment s. I had read in a similar post how Anchoring concrete was recommended, so I was planning on using it as a patch. Sound correct? Any and all help is appreciated..
    i
    Attachment 47550
    15k gallon irregular shape Pool with an attached 8 foot diameter SPA 16 jet. 160340 Cartridge Pool Filter, 320 Square Feet.460736
    Pool Heater, NG 40K 601002 IntelliBrite 5G Color LED Pool Lightx2
    520555 IntelliChlor IC40 Salt 520556 IntelliChlor Power Center.011513 EF Single Pump1Hp,
    521221 IntelliTouch i9+3.011519 EF Single Speed Up Rated Pump2hp,x2
    Casey's Avatar
    SW PA
    10,457
    Re: Hello, I'm Guy.
    Welcome!
