Results 1 to 15 of 15
Thread: Low Pressure
    Low Pressure
    Happy Pool Opening Season!
    I noticed the pressure on my filter was low, below 10, so I took apart the system and cleaned out the filters (cartridges) and cleaned them as they were pretty dirty. Put it all back together but alas, the pressure is still low. Any thoughts here? Is low not a big problem? The return lines seem to be blasting fine.
    Gunite. 14,869 Gallons. Hayward cartridge filter. Hayward Super Pump 1HP. Chlorine.
    Baltimore, MD
    Jun 2014
    15,070
    Re: Low Pressure
    Normally you would think dirty filters would increase pressure. I would relate low pressure to something like no filters inside the housing (no resistance) or low flow (pressure) to the filter itself from the pump. But return jet output pressure seems good huh? Perhaps the gauge itself is beginning to fail and just now showing some indications this new season?
    Re: Low Pressure
    Ok. Thanks. Is there way to test the gauge?
    Baltimore, MD
    Jun 2014
    15,070
    Re: Low Pressure
    Ooh, test? I'm not aware of an easy way. But if you end-up trying to buy one, you can get one at TFTestkits.net for just over $12, and they are good quality gauges.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Low Pressure
    Quote Originally Posted by RSAnative View Post
    Does it go to zero when the pump is off? If no, it's bad. It can still be bad if it froze over the winter even if it does go to zero.
    A suction side air leak, even one caused by low water level or a stuck skimmer weir can give you low pressure. Are there a lot of bubbles inside the pump strainer basket when it's running?
    Apr 2016
    Middle Tennessee
    6
    Re: Low Pressure
    For what it's worth, I had to replace my pressure gauge last year after I noticed that it stayed at 10 psi whether running or not.
    24' Round Above Ground: 18K-ish Gallons - Vinyl - Bleach Chlorination - Waterway 1 HP pump with EcoKleer 19" Sand Filter
    Re: Low Pressure
    It goes to zero when the pumps off. No air leaks that I can see. When it's running the pump basket is clear of bubbles. I did notice something else; When I bleed the air on the top of the filter, it definitely doesn't sound like it's high pressure and then once the water comes out it immediately starts to flow slower coming out of the bleeder.
    Baltimore, MD
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low Pressure
    You may have a partially blocked impeller. Remove the pump basket and feel inside the opening at the bottom of the pump housing. Remove any debris that may be stuck in there.
    Mark
    Re: Low Pressure
    I did. I pulled out a few things that I could reach but nothing major. Do you think I have to take it apart?
    Baltimore, MD
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low Pressure
    It is possible because something could have gotten stuck in the vanes. Given you pulled something out of the inlet, there is a good chance there is something stuck in the impeller vanes too.
    Mark
    Re: Low Pressure
    Ok. Is that something an amateur like me can do without totally destroying the motor?
    Baltimore, MD
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low Pressure
    Yes it is pretty easy for most pumps. What is your pump make and model?
    Mark
    Re: Low Pressure
    Hayward Super Pump 1 HP.
    Baltimore, MD
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low Pressure
    There are four bolts that hold the motor mounting plate to the wet end. Remove those four bolts and slide the motor backwards. The impeller will be attached to the motor shaft. You can then inspect and clear out any debris. It would be a good time to inspect the seal (without removing impeller) and any gaskets for cracks.
    Mark
    Re: Low Pressure
    I'll try it after the storm.
    Baltimore, MD
