Results 1 to 12 of 12
Thread: Waterway Sand Filter Problem
    Mar 2009
    Manitoba, Canada
    19
    I have a brand new Waterway Carefree sand filter (well, not brand new, but never been used). I just got it set up and filled the pool to the skimer to test it out. When I set the valve to Filter, I get a fair amount of water going to Waste as well as to the pool. Guy at the pool store said it needed a new divertor gasket, could that be right? This filter has never been used and looks brand new, why would the gasket be bad. He also said they recommend buying the divertor as well because it comes from the factory with the gasket glued on. Any thoughts?
    Thanks.
    21 foot AG 10,000 gallon, Waterway pump and Waterway Carefree 19" sand filter
    Re: Waterway Sand Filter Problem
    The gasket he is talking about is in the main valve, typically a rotary valve that allows you to select filter, backwash, waste, circulate, etc, though some of them are push/pull valves with only two positions. Often this valve is replaced when the filter is replaced, but you could still have the old valve.
    If the valve was replaced along with the filter, then the installer should take care of it for free. If you still have your old valve then the gasket should be replaced, which is simple enough and probably something you could do yourself if you feel up to it.
    Mar 2009
    Manitoba, Canada
    19
    I'm pretty sure the valve is new as well, but I could be wrong, I got everything from the guy that I bought the pool from.
    I am the installer, so yes, I will be doing it for free.
    Any chance it could be an install problem, and not the gasket?
    Inside a rotary multi-position main valve there is a gasket, many people call it a spider gasket, that keeps the valve sealed. This gasket should be fully seated in it's channel and free of any nicks or cuts. Most pool stores will carry replacements, though you need to know the exact model number of the valve.
    A torn spider gasket will allow the valve to leak internally and water will come out the waste pipe. There are also other things that can cause the same symptoms, though they are less likely. The spring that applies pressure to the spider gasket can break, or the main rotary assembly inside the valve can break. All of this can usually be determined quite easily once you have the cover off the valve and take a look inside.
    None of these issues are normally caused by mistakes during the install. The valve can break when it is dropped, but valves are fairly sturdy and breaking them is very rare. The most common install problems are leaks at the pipe joints or accidentally gluing the entire rotary assembly to the case so it won't turn.
    Mar 2009
    Manitoba, Canada
    19
    Thanks. I'll take it apart today and have a look.
    Yep, found that out very quickly. Another mistake is not putting a shutoff valve by the skimmer. Had to drain some water from the pool to fix my leaks. I tried to use all the plumbing/fittings that came with my used pool, and had to pretty much redo it all.
    Jun 2007
    New Jersey
    653
    I had to replace a MPV on my Waterway DE Filter due to an equipment change. I ordered straight from the factory and it arrived missing the spider gasket completely. No glue marks, nothing, it was never installed. They air couriered one out to me.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by rickpenner
    I like your sense of humor. You will fit in nicely here.
    Welcome!
    Mar 2009
    Manitoba, Canada
    19
    Quote Originally Posted by frustratedpoolmom
    Welcome!
    Thanks. I'm impressed by the activity and quick responses on this site. Very helpful! A lot of my questions were answered just by reading all the info here!
    Mar 2009
    Manitoba, Canada
    19
    Well, I'm still having problems with my filter. I replaced the spider gasket even though the old one looked fine. I still have dirt coming into the pool thru the return when I vacuum, and water leaking to the backwash hose when filtering. My pool is clear until the kids go swimming, then they stir up all the dirt at the bottom and it gets cloudy.
    I suspect now that it's because there is not enough pressure to push the gasket down. I took everything apart and lubed everything. The handle seems to work well (springs back up after I push it down) until I put the lid back on the filter and screw it down. After that, the handle tends to stay down (not spring back up like it should). In other words, I push the handle down, turn it to whatever position I want it to be at, but the handle does not spring back to push the gasket down. I am going back to the pool store today to look at a new valve assembly to make sure mines pu together right, but I think it is.
    Any ideas?
    UPDATE: I went to the pool store and inspected a new lid assembly. It looks exactly like mine, so I know mine is put together right. I took it apart again (twice) to try and figure it out, but still have the same issues. I'm thinking of buying the whole lid assembly new, but am worried it still won't work. Is it possible that it could be the valve assembly, that for some reason isn't letting the gasket seal properly?
    Mar 2009
    Manitoba, Canada
    19
    Re: Waterway Sand Filter Problem - Warped Valve Assembly
    Well, I figured I would finish off this thread in case anyone else has the same problem. My filter problems (leaking to backwash when on filter mode, dirt coming back into the pool) were due to a warped valve assembly. If the surface that the spider gasket contacts with is not straight/level, it won't seal properly. Apparently this can happen if you have a heater and leave the heater running when the pump is off. The HOT water can do significant damage. I don't have a heater, but the previous owner of the pool/filter did. He was not using this filter when I bought the pool, he claimed it was "new" and it did look new, inside and out. The only way that I could see it wasn't new was when I took everything apart, and there were wear marks on the spring. I think he either wrecked it himself, or bought it from someone else thinking it was new. Or, the valve assembly was defective from the factory???
    BOTTOM LINE, if you have symptoms that are usually diagnosed as a bad spider gasket or worn/broken spring, 90% of the time it probably is one of those things, but it could also be the valve assembly itself ( the part that sits on the filter with the in/out/waste ports).
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    So, are you going to replace it or have you found a fix?
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Mar 2009
    Manitoba, Canada
    19
    Pool store gave me a good price on the whole assembly, including new valve, so I replaced it all. Just did it last night, no more water out the backwash hose, I guess we'll see over the next while if it totally fixed the issue with the dirt going back into the pool. I do suspect that my pump is oversized for my filter (1hp single speed pump, 19" filter with 100 lbs of sand). From reading other posts it looks like that could be an issue as well.
