Thread: vacuuming
    May 2015
    Clarksville
    146
    vacuuming
    another thing I struggle with.
    when I vacuum, can I vacuum to the filter, as the sand filter foes have a basket to catch debris +a recirculation setting.
    or should I vacuum using the skimmer and plate I bought that fits my skimmer?
    I normally use this vacuum that has a built in debris bag, but I honestly find it leaves things behind, and is not weighted so it sometimes floats upward as I move it about the water. I am honestly sick of it, and as you know intex pools don't come with a thru-wall skimmer.
    see photos so you know what I'm referring to.
    Intex 18/52 pool at 7000 gsllons.
    vinyl sift sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
    vinyl soft sided pool
    Re: vacuuming
    If you vacuum through the skimmer then you leave in the skimmer basket which then collects the debris before it gets to the pump. You can put a stocking over the basket to trap finer debris.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    May 2015
    Clarksville
    146
    Re: vacuuming
    tah I have the basket in there. it's under that plate you saw.
    May 2015
    Clarksville
    146
    Re: vacuuming
    I got a new weighted head, but it connects directly to hose so it would work through skimmer or pump. sorry. forgot to mention that before.
