Results 1 to 11 of 11
Thread: What type of tubing for liquid chlorine (bleach) feeder?
    Mar 2015
    Plano, TX
    18
    I am working on a pool automation system using an Arduino, and I plan to use a peristaltic pump to automatically chlorinate the pool with bleach. I am considering Tygon tubing, but I can't find a solid answer on whether or not bleach will eat it. Does anyone have any recommendations for what type of tubing I should use? It needs to be flexible and springy like silicone tubing in order to work in the pump.
    1982 built 15K? gallon IG gunite/plaster, DE filter, Pentair Challenger 1.5HP pump, Polaris 280, Pentair LA01N booster pump, 3-8' with diving board, K-2006 test kit
    May 2014
    Jacksonville, FL
    22
    Re: What type of tubing for liquid chlorine (bleach) feeder?
    Santoprene or Norprene
    19k gal, IG, Rectangle, Pebble, Pentair Clean & Clear Cartridge, Intelliflo VS Pump, IntellichlorSWG, Aquacal SQ-155 Heatpump, Aquaclean Aclean1 Robotic Cleaner, TF-100, Dec 2013, Jacksonville FL
    Apr 2013
    Sacramento, CA
    2,769
    Waterway Shurflex Clear Vinyl Tubing - 3/8 - 110-0120
    Home Depot clear plastic tubing sold in the plumbing section -- works just fine.
    Jun 2015
    Tallahassee, FL
    30
    I went the peristaltic pump route also, a cheap 12v one from amazon. As for tubing, cheap aquarium 1/4 inch OD (I think) slips over the small tubing that's in the pump.
    I do remember a youtube vid showing how to cut away some plastic to actually use the larger tubing than what it comes with.
    But I've been using that pump quite nicely on a timer for about a year now. No problems with either the pump tubing nor the aquarium tubing. If you really need it I can get into my Amazon acct. and give you the actuals.
    Cheers.
    Edit: There seems to be no degradation of the tubing at all using 10-12.5% chlorine sucked strait from the bottle.
    Intek 18' X 48" AG, filled to 36-42"(slope?), Intek sand filter/pump, Hayward skimmer
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have used the hard ice maker plastic tubing with no problems, I am not sure of the material name though.
    Dec 2014
    Riverside California
    482
    A lot of people with Stenner pumps just use the black 1/4" PVC tubing supplied with the pump. The black tubing is UV resistive while the clear tubing will be degraded by UV.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agree with Gary300.
    If this is in the sun, most common clear tubing will be ruined by the exposure. Save Tygon, and Teflon. Black Parflex tubing will last a very long time, and handle anything pool chemical wise for years on end. I've run hundreds, and hundreds of feet of it for more aggressive products in addition to bleach and Sulfuric acid. Never seen a failure related to chemical, or uv exposure. It's relatively cheap, and easy to find at irrigation supply houses.
    Essential Links:
    Apr 2016
    Rockville MD
    43
    With the black tubing, how can you tell if the system is primed without seeing the air bubbles getting purged?
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    May 2011
    Dorset, UK
    33
    I bought a condensate pump (Aspen universal) for an AC unit for 15. I did not change the tube within the pump at all. I then used 2 sizes of PVC tubing, the larger to fit onto the pump hose barb, and the smaller to fit into the injector. The pump and pipe are not in direct sunlight. I used standard pool pipe solvent cleaner and glue to seal the smaller pipe inside the larger pipe. Been working for 2 years now.
    All controlled by HomeSeer and Arduinos.
    12ft x 24ft x 4ft inground vinyl, 32,000 litres, 3 phase 1.25hp Waterco pump on DIY VFD for cheap variable speed. 18kW Heat pump, Lacron sand filter, Solarmatt, 10kW Solar PV
    Jun 2016
    Houston
    2
    Can you send a link or picture of your setup. I'm thinking of doing the same thing
    TEXAS
    34
    I used Clear Vinyl Tubing and after about 8 years it became brittle. I'm about to redo mine and will be using beverage tubing. If you don't have yours sorted yet I have thousands of feet of tubing I could let you have.
