Results 1 to 8 of 8
Thread: 2sd year pool owner. Skimming issues
    May 2015
    Atlanta-GA-
    69
    Hi
    I am in the process of slamming my pool, I am almost done. I have noticed that my pool has a lot of fine particles floating on the surface (Really small stuff as I net everything that falls in daily). Filter is going strong and water level is fine. I do not remember having that problem last year. Any solution?
    Thanks
    Pat
    12' AG, 3200GA, cartridge filter, pool installed 6/20/2015, Taylor K-2006 test kit,
    Jun 2014
    15,205
    Re: 2sd year pool owner. Skimming issues
    If you are currently SLAMming, I suppose it could be residual algae floating around until it gets filtered. Also possible you just have pollen in the air at the same time and it's settling on the water. You're welcome to post a set of test results for us just to see if there's something we might notice that would help. ..... the "other Pat"
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    sounds like pollen maybe...is there anything else in the pool right now? i left some noodles in last year and they started to break down and leaving stuff in the pool.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2015
    Atlanta-GA-
    69
    Nothing left in the pool from last year. The stuff floating is mostly whitish in color.
    Thanks guys
    Pat
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Here in Augusta we've got that too... just some pollen I'm sure.
    If in doubt you can perform an OCLT (See Pool School for directions) and it can help tell you if your pool has a nascent algae bloom or not. If not, assume its pollen at this point in the year.
    FloridaPoolGal's Avatar
    Jan 2016
    Altamonte Springs, FL
    98
    We were having issues with lots of small bits floating on the surface and the solution for us was using hairnets on our skimmer net. It's been an excellent solution because it is both effective and cheap! 100 hair nets for $6.08 delivered from Amazon. There is a thread on the subject but I don't know how to embed a thread into a message.
    Approx. 20k gal, kidney-shaped, inground, concrete pool built in 1974. 33' long. 18', 14', & 15' across. 3' to 8' deep. Hayward cartridge filter (c1200e). 1 hp, single speed motor replaced 12/2015. In-line Pentair 320 Chlorine/Bromine feeder (do not use). Screened.
    May 2015
    Atlanta-GA-
    69
    yes it is probably pollen. I won't worry about it for now.
    Nice hairnet trick
    Pat
    Jan 2016
    98
    I was reading another thread about someone cleaning out a green monster and I think these hairnets would come in very handy. Since you just peel off the hairnet, there's not net cleaning required (I'm assuming it gets dirty during the cleaning process).
