Results 1 to 9 of 9
Thread: Skimmer socks
    Jul 2015
    Port Neches, TX
    53
    Skimmer socks
    [QUOTE=klynch494;1006193]
    A good piece of advice I learned from here was running a skimmer sock (aka hair net) when i find extra debris or heavy loads of pollen. Found here...
    https://www.amazon.com/gp/aw/d/B002X...?ie=UTF8&psc=1
    I ordered these last year, worked great from what I remember. Hubby left them outside most of the summer (in shade), but it gets pretty hot here in Southeast Texas. It seems like they are way more fragile, sometimes get a hole in them just pulling one out of the bag, and the "stretchy" elastic part does not spring back, so many times the net is all collapsed in the skimmer basket on the sides. Is that how these normally are, or did the heat degrade them?? Or does anyone use a different type/brand that may be sturdier, but not the actual socks that are not disposable?
    Any input would be appreciated. Thanks!!
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Skimmer socks
    I purchased these this weekend, they have not arrived yet. I like the idea of 7˘ per net, the ease of purchasing, no taxes, no shipping, and the ability to just pull off, toss, and replace. I will report back my results. Shipping takes about a week, so see ya next week.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Skimmer socks
    I've used these for about a year with no issues. At $0.07/per, if I tear one then eh... ok.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jul 2015
    Port Neches, TX
    53
    Re: Skimmer socks
    I'm just gonna buy a new order. I went through 6 just today by then tearing just from pulling out of the bag!! I think the heat fried them. They are cheap enough just to throw out!
    Oct 2015
    Katy/Texas
    411
    Re: Skimmer socks
    I am on my second package of these hair nets and have not had any failures. I store mine in an outdoor cabinet on the covered patio.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jun 2014
    15,037
    Re: Skimmer socks
    I must be the oddball. I use 1-gal paint strainer nets from Home Depot. One net lasts me almost all season. I will have to break my comfort zone someday and try these just to compare.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Skimmer socks
    I have been using the hair nets mentioned by tamaralemus above for a week now. Just changed out my first set. I think they are close to ideal, but I do have to resist my desire for a skimmer sock to trap every tiny little particle.
    Pros
    1. A joy to remove, throw away, and replace. No rinsing out dirty old socks.
    2. Water flow virtually unimpeded, even after one week.
    3. 7 cents each
    Cons
    1. They don't seem to get as coated with dust and pollen as a real sock - very small particles probably pass right through.
    I guess its all about your preferences. I am going to stick with the hair nets, at least until my first filter cartridge clean, and then we shall see. Until then, I will let the skimmers skim, the filter filter, and use the hair nets to help ease the filter's load.
    Besides, I have 96 more, lol
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Re: Skimmer socks
    Quote Originally Posted by Texas Splash View Post
    I have 4 of these too. I just pull the dirty one out, replace with a clean one. Hang the dirty one up to dry, shake out, and reuse. They work great!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jul 2015
    Port Neches, TX
    53
    Re: Skimmer socks
    I did reorder some, and they are fine. I guess being that they are a year old and were in the 90+ summer heat they degraded. The new ones are perfect. Has anyone tried using one inside the other to catch the smaller stuff?
