Thread: Is there ANY auto cleaner that will work with 1200 GPH pump?
    Apr 2016
    Casa Grande, AZ
    66
    So in an attempt to avoid lesson #3 (see other posts) - I am posting this new thread. We will finally have this pool ready for swimming tomorrow. Now I am starting into the ongoing phases - chemistry and maintenance.
    HOWEVER, this is our first pool, and a large point of it was to "test the waters" and see how we like it before spending a lot of money.
    So, our pool 18x9x52 came with a 1200 GPH Sand Filter/Pump (SF90110T model). I know there are plenty of folks here who will say the pump is inadequate - but many others say it works ok (if not optimal). Given my sentence above (about this being a "test"), I am hesitant to go spend another $200.00 on a pump right away if this one gets the job done at a basic level. If we end up liking this pool life - I have no problem upgrading if it will make my life easier.
    BUT, in the meantime there will be maintenance! After our Leslie's fiasco, and then Mickelin's suggestion that the less expensive Intex auto-cleaner may be fine for us initially - I started researching between that and the Aqua-bug.
    But I am finding that a lot of folks mention that NEITHER of these will work with a 1200 GPH pump. Am I resigned to hand vacuuming until I upgrade? Or will either of these work at 1200 GPH - just not as well? Is there another model out there that is better suited for the 1200 GPH?
    Thanks as always!
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Is there ANY auto cleaner that will work with 1200 GPH pump?
    you could try a robot cleaner that works by itself with no pump needed...
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Apr 2016
    Casa Grande, AZ
    66
    Thx Titleist - aren't those even more expensive that buying a new pump? I just went ahead and ordered the manual vacuum for now while I see how this pump works for even normal filtering.
    Jul 2014
    Lodi Ca
    189
    It depends on the brand and type, if you want to keep on a smaller budget until you decide if you like the pool life, you could always look at the internet auction sites or local listings ...
