Thread: Ultra-Frame Pool set up with Overlap Liner
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Ok, so I read some threads on here about setting up an Intex-type pool and using an overlap liner instead of buying a new one (costs almost as much as a new pool). So I decided to do that this year for a couple of reasons. First, when I set up the new pool last year on the patio, I didn't have the ground cover completely under the pool. Result was several small leaks on the bottom near the walls. Second, I really liked the idea of being able to get a nice pattern with the new liner and the one I got (25ML) was only $125.00.
    The initial set up was OK, but when I started to fill it, the liner settled more than I thought it would. The little tarp hook things started popping off and it really freaked me out. I had to re-snap them several times. I would fix one and another one would pop off. Then another, and another. Those things will kill your hands/fingers. They are not easy to snap on. Not at all.
    So end result, once the water got a little over half way, the "popping" of the tarp snaps stopped and everything settled into place. However, what started as a perfectly lined up liner, ended up being uneven in many places. BUT, the inside does look great and it seems to be very stable. I think we are going to enjoy it this year, but, I doubt I will be doing this again. I will probably just get a new pool next year. Oh well, live and learn.
    But again, on the bright side, we have a beautiful pattern to look at and most importantly, OUR POOL IS UP! Water is pretty cold, but the pool is up! I got to use my TF100 for the first time this year and let's just say, I Love it. I Love having crystal clear water and being responsible for it all on my own.
    Now come on warmer weather!
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2015
    Charlotte NC
    225
    Re: Ultra-Frame Pool set up with Overlap Liner
    Ant
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Looks good, great job!
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Casey's Avatar
    SW PA
    10,448
    Very nice!
    May 2016
    Joliet Illinios
    2
    How did you cut the inlet and out let for filter??
    Jun 2015
    Charlotte NC
    225
    Quote Originally Posted by Mehring View Post
    I have a thru the wall skimmer and 1 return. So first, you have to put enough water in there to hold the liner in place (just below where the lowest cut you have to make). For the skimmer, I placed the plastic square and gasket on the inside lined up with the pre-existing cut-out. The old liner already had holes where the screws go thru it, so I just used the screws to poke thru the new liner fed them thru the existing holes. Then I put the outside plastic and gasket thru the holes and screwed everything into place. So then all I had to do was use an exacto-knife and cut it out. No leaks, worked great.
    For the return, I just held the new liner against the old liner (again, the water helped hold it in place) and just cut it out from the outside thru the existing hole. It was easy.
    Ant
