Thread: Check Valve?
    Feb 2016
    Roselle, IL
    39
    Check Valve?
    I am getting ready to install a new heater on my new pool this weekend. I was reading my installation and operations manual from the heater and they recommend a check valve be installed between the heater output and any SWG or chlorinator. Anyone done this? Anyone have a picture?
    Can you recommend the size check valve? The heater has 2" plumbing, but my system will be 1.5" hard piped. I could use a 2" check and downsize on the back of it or use a 1.5" check. Personally I like to use the bigger check valve since the valve is usually smaller than piping coming in and out, creating a restriction.
    Thanks.
    13,200 GAL Aqua Leader Influence 54" AG | Heyward S244T Sand Filter (250 Lbs.) | 2-Speed Hayward Pump | RayPak 206 Cupro Nickel Natural Gas Heater | Hard Piped | Kontiki 2 Suction cleaner | TF-100 Test Kit w/ SpeedStir | 2016 Install | Chicago Suburbs
    38,521
    Re: Check Valve?
    No check valve needed for a SWG. Definitely need one if you have a Trichlor tablet dispenser.
    Better to use 2" plumbing at the pad to reduce head loss. If you install a check valve, get the ones like the Jandy Neverlube.
    Feb 2016
    Roselle, IL
    39
    Re: Check Valve?
    Thanks Jason!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Check Valve?
    Just seconding the Jandy check valves
    Feb 2016
    Roselle, IL
    39
    Re: Check Valve?
    Thanks everyone.
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Check Valve?
    Lots of folks put them in but if your chlorinator is further down the line no real need. Keep in mind that the there are two different check valves and one holds up under higher heat than the other. I see lots of the flapper ones where the flap is all curled up do to the hot water. Usually because the heater doesn't go thru a cool down period and thus the warm water melts the flap over time.
    Here's an example of a check valve used for heaters. Amazon.com : Jandy 7305 180-Degree, 2-Inch to 2-1/2-Inch Check Valve : Swimming Pool Pump Parts : Patio, Lawn Garden
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
