Thread: Is A&H washing powder the same as Borax?
    Is Arm and Hammer Washing Soda the same thing as Borax? I'm getting ready to do an ascorbic acid treatment to my pool due to metal stains and want to make sure I have everything I need. Thanks.
    In-ground pool owner in NW Georgia: 18 x 37 IG Grecian vinyl pool installed April 2011: 27k gallons, Hayward SWG auto-cleaner with booster pump, Hayward Aquarite T-15 Salt System with timer freeze controls, Hayward Aqua Plus, 1.5 HP Tri-Star pump, 48 sq. ft. D.E. filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Is A&H washing powder the same as Borax?
    Quote Originally Posted by tcordle View Post
    No. Either will raise pH. Borax will raise borates as well. Washing Soda will add TA.
    Thank you, Richard320. I appreciate it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Here is the best chemical cheat sheet ever, Pool School - Recommended Pool Chemicals
