Thread: Grill Hanger Flange
    Grill Hanger Flange
    Hello All! Iím in the mid stages of building an outdoor kitchen. Yesterday I made the cutout for the grill, and now my wife and I are in a debate. So the grill has a SST hanger flange that goes around the sides and back. The grill is suspended on this flange. The question is: Does the granite go over the flange so that the flange is sandwiched between the metal frame and the granite, or does the flange sit directly on top of the granite? I see pictures of it both ways when I Google it.
    Thanks a ton for any insight. Iíll post pictures when I get it done. Probably early June.
    In ground Pool, 13,000 gallons, Cartridge filter (big), Single pump, Hayward Goldline Aqua Rite
    Central Florida
    Miller Lite
    Tony Stewart
    Jul 2015
    Central Valley CA
    1,108
    Re: Grill Hanger Flange
    I like my sinks under mounted so you can just wipe into the basin. Grills I like over mounted because no matter how careful you are, you are going to get a spill down the side at some point and with the flange you can clean it up a bit easier. If you under mount you just have a gap that is going to get some funky stuff in it over time. The other thing to think about is there may be a time you want to remove the grill to either detail it or replace it with a better one and you don't want to have to relace or risk breaking the granite
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    So you’re saying that there’s no “right” way. Functionally, both will work?
    Central Florida
    Miller Lite
    Tony Stewart
    Jul 2015
    Central Valley CA
    1,108
    I think the manufactures intended them to be top mount drop in. Read the manual as long as there is no minimum gap that needs to be maintained between the grill body and counter and putting under is not going to get in the way of the lid hinge then it's your kitchen do what you want. I can't think of any harm it would cause. If you are still undecided call the manufacture I am sure they will tell you if it is a bad idea.
    Mar 2015
    Sugar Land , TX
    424
    I have mine mounted on top of the granite. Like mentioned above I have spilled cooking drippings and makes for a easier cleanup. Plus if you ever need to take the grill out it is alot easier if top mounted.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
