Results 1 to 16 of 16
Thread: 48 hours in SLAM- on track ?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I'm 48 hours in and looking pretty good with only 1 ppm loss of chlorine overnight.
    This morning:
    FC: 15
    pH: 7.4
    TA: 100
    CYA: 40
    There are a lot of particles in the water I'm measuring. I added 1 cup of cellulose fiber thinking that might catch some of that.
    Visibility is about 18-20" down. I've brushed and vacuumed as long as I could see black stuff come up (since I can't see down there.)
    Am I on the brink of a breakthrough? It seems like this same Aqua green color has been same for 18 hours.
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: 48 hours in SLAM- on track ?
    You're 90% through!
    Unfortunately, like so many things in life, the first 90% takes only 10% of the time, and the last 10% takes 90%. Someone can frame a house in a day, but it takes weeks to finish, right?
    Okay, maybe 90% is a little extreme. But you are making rapid progress and you obviously understand what's going on. The fiber in the filter should really help speed things along. Do whatever you can to improve circulation down low where the stuff settles. Point a return down, or set the vacuum head on the floor but turned sideways so it acts as a drain. You want to strain out all that particulate matter, so you have to keep it in circulation so the filter can grab it.
    Jun 2014
    15,023
    You are definitely on the right track! Keep it up and don't slow down. Make sure to keep your FC at 16 based on your CYA. But your low TA concerns me. You might want to add some baking soda just to get it up to about 50 or so. A TA of 10 is quite low....assuming the test was performed correctly.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks Richard! One of the things that can really screw up ones efforts is misreading CYA. Is there somewhere on here some good illustration on what it means to understand "can no longer see black dot" in that test. I started with zero CYA and used a very measured and stingy process with some dichlor to raise it.
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Edit: TA is 100
    TFTest Kits TF-100
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by cfclay View Post
    Jun 2014
    15,023
    Ooh! That's better. Normally we don't worry about it, but I had to ask. Keep-up the great work.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Still slamming over in Little Rock with about a 3-4 point lose in chlorine overnight. Full day 5 with
    FC: 16
    TA: 100
    PH: 7.5
    CYA: 40
    I can see the pool lines now!
    Just keep on doing what I'm doing?
    Seems longer than I hoped for.
    TFTest Kits TF-100
    Jun 2014
    15,023
    Outstanding!
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Quote Originally Posted by Texas Splash View Post
    Outstanding!
    It ain't sparkly yet
    TFTest Kits TF-100
    Richard320's Avatar
    Jan 2010
    18,967
    It took more than five days to go from clear to scary. You're actually doing very well time-wise.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    That's why I recommend this forum! Thanks for the support!
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Made it! 7 days in!
    TFTest Kits TF-100
    Richard320's Avatar
    Jan 2010
    18,967
    Made it! 7 days in!
    Impressive.
    How much do you reckon that water would have cost you from the pool store?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Hmm. Hard to say . I used about 9 gallons of bleach and a couple cups of dichlor I pulled out of the closet.
    TFTest Kits TF-100
    Jun 2014
    15,023
