Thread: EasyTouch 4
    aguyindallas's Avatar
    Apr 2016
    Little Elm, TX
    127
    EasyTouch 4
    My pool is under construction and at the time of design, my PB gave us the option of the wireless control pad or having a network adapter that allows controls from our phones and iPads etc. they said to have both, it's another 1k. We opted for the network adapter that gives us wireless device controls.
    I'm second guessing my choice right now and am considering adding the wireless pad.
    My question: Is it easy to add the wireless pad option myself after all of this is completed?
    11.5K Plaster, level spa, Salt with Pentair Equipment.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: EasyTouch 4
    I have the remote/pad for mine and no network hookup, but if you can get that to work, I don't see you needing both. I just can't say how dependable or not the wireless/network connections are. I'd ask the PB about the complexity of the install later if it were me. Sorry I'm not more help, but there may be others along to shed more light on it. Good luck in whatever you decide.
    Essential Links:
    May 2016
    Spring, Texas
    3
    Re: EasyTouch 4
    I had the remote pad, but it eventually died (was about 10 years old) and replaced with the application on our phones, ipads, computers. I prefer the application as it gives you the ability to control your pool when you aren't home (like turning on your spa heat before you get home so you can have a hot soak in the winter). Network issues shouldn't be any worse with this solution than the old remote/pad option. If your internet connection is down, you won't be able to control the pool when you aren't at the house, but you can still control it from home. With the old remote/pad option you can only control the pool from home all the time.
    I don't know how easy it is to hook both options up - it was VERY easy to switch between the two though. Basically, plug a new wireless antenna to your control panel, and connect a small access box to your router in the house.
    Good luck
    Jeff - Texas - 20,000 gal saltwater free-flow gunite pool with boulders, waterfall, grotto, spa with flagstone spill way, easy touch 8, wireless/mobile app control, Letro Legend w/ pump, intelliflo waterfall pump, variable speed pool/spa pump, fountains, spay nozzels and weeping rock wall.
