Results 1 to 12 of 12
Thread: scaling?
    Oct 2015
    Houston, Texas
    14
    scaling?
    Need help please. New pool built January 2016. i am starting to see a hard white film on some of my waterline tiles. I noticed some on the tiles on the steps. it does flake off. Is this scaling? What should I do?
    date: 5-1-2016
    PH 7.8
    FC 11
    CH 675
    TA 60
    CYA 45
    My fill water CH is 100.
    We have had lots and lots of rain in Texas recently.
    Here are some previous numbers:
    date: 4-23-2016
    Ph 8.2
    FC 7.5
    CH 625
    TA 80
    CYA 55
    date: 4-16-2016
    Ph 7.8
    fc 5
    ch 750
    TA 70
    CYA 65
    date: 4-8-2016
    ph 7.8
    fc 5.5
    TA 70
    ch 625
    CYA 72
    22 x 36 ft. in ground Free Form Salt water pool; 8 x 8 raised spa; 3 ton Mossrock waterfall with its own Pentair Whisperflo 1.0 HP pump; Filter 60 sq ft Pentair FNS Plus D.E. Filter; Pentair Whisperflo Pump 2.0 HP for pool; Pentair MasterTemp Natural Gas Heater, 400k BTU; Polaris 280 w/ booster pump; Pentair Intellichlor IC40 Salt System; Ozone Joe Water Purification System; LED lights; bubbler on sunshelf
    May 2016
    south australia
    1
    Re: scaling?
    thats sound to me its crystallizing (calcium hardening) needs to be removed by 50/50 water and acid (gloves) and a brush
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: scaling?
    Are you using calcium hypochlorite for shocking?
    I don't understand how you could go from a CH of 100 to 600 in less than 4 months?
    The white deposits, do they run horizontal at the waterline, or do they go vertical above the waterline? Vertical is usually an indication of efflorescence. However, given your pH, TA, and CH levels, waterline scale is very possible
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: scaling?
    Especially not with all that rain, rain should lower your CH, especially the feet of rain ya'll have had this spring. If you are using cal-hypo stop, it is adding calcium to the pool.
    Anyway, here is what to do to prevent calcium scaling. Manage your CSI to be slightly negative, -0.1 to -0.3. Enter all your test results into Poolmath including water temp. Poolmath will calculate your CSI score. Tweak PH and TA to keep it in range. This will make your SWG stay clean and last longer and will add years to the life of your plaster.
    More here, Pool School - Calcium Scaling
    And here, Langelier and Calcite Saturation Indices (LSI and CSI)
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: scaling?
    What are you using to test?
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    Tf 100 test kit
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    I have shocked it with the packs the pb gave me. I will check what it is and post
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    Quote Originally Posted by bdavis466 View Post
    I mainly see it where my spa waterfall goes into the pool on the waterline tile. I saw some on a one inch tile on my tanning shelf. It's a very hard white filmy substance. I will post pics of it.
    30,419
    Re: scaling?
    Lower your pH. Get it down to 7.4 and keep it there.
    I suspect your pH has been even higher at times than the tests reflect.
    High pH is a primary contributor to scale.
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    Yes I have to constantly add muriatic acid to keep it down
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    Can't figure out how to post a pic just yet but the shock I was using is;
    Poolife turboshock
    active ingredients: 78% Calcium Hypochlorite
    22% Other Ingredients
    So I'm guessing that is where the calcium is coming from. So should I do a partial drain or just keep the PH in check?
    Oct 2015
    Houston, Texas
    14
    Re: scaling?
    And CSI
