Thread: Spa jet help, please
    Sep 2015
    Avondale, AZ
    87
    I have a missing spa return jet, as well as a few broken pieces (I bought the home with the spa in this condition). I'd like to replace everything. There are five jets total. I can't seem to find the right pieces though. I'm also curious if I have better options (spinning jets to replace the eyelet, maybe? I don't mind if it protrudes a little). Also, the return pressure is a little lower than I'd prefer so I'm also thinking maybe smaller internal jets should bump up the pressure a bit? Here's what I have. Do any of you have any suggestions as to what would be best? Thanks!
    Approx 25k gallon PebbleTec in-ground diving pool and attached raised (10 person?) spa, with spillover and waterfall.
    Hayward AquaLogic PS-4 control board, Hayward SP3400VSP Ecostar pump, Hayward C5520CP cartridge filter, Hayward H400FDN 400k BTU NG heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Spa jet help, please
    that sure looks like your standard 1.5 inch eyeball jet there are many to choose from
    Amazon.com: 1.5 inch pool eyeball
    Sep 2015
    Avondale, AZ
    87
    Thanks. The threads are bigger than 1.5 though. They are 1.75 (I think). I haven't seen anything in that size.
    Sep 2015
    Avondale, AZ
    87
