Thread: FNS 60 Filter Grid help
    May 2016
    Barberville, Fl
    2
    I was in the process of cleaning my fns60 filter grids when i noticed that the bottom of all the grids where the threading is are mostly gone. I could literally slide the filter mesh off of the skeleton grids. I'm assuming I can't reuse these? Is that correct or is this normal for these to do this? I found it odd that I didn't have any DE or anything else bad in my pool.
    May 2016
    Barberville, Fl
    2
    Re: FNS 60 Filter Grid help
    After investigating it further, I'm not sure if there was ever any theading on these as they are all opened up at the bottom. The threading on the top of the grids are all fine. It's the bottom of the grids that are opened up. Can I reuse these? The actual grids and mesh are in great shape except for the bottom.
    Very strange, never seen that before. The fabric has to be completely sealed. If you can't seal the fabric, you'll need new grids.
    Maybe sew them or glue them shut.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Break out the dental floss and a needle.
    My brother-in-law has successfully repaired grids by sewing the tears shut and then smearing the offending area with silicon gasket goo. I imagine caulk would work just as well.
    Jan 2012
    340
    If all your other grids are in good shape, just replace that one. Shouldn't be more than 20-30 to replace even from local pool supply.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
