Results 1 to 13 of 13
Thread: Is it time for a new pump?
    GMil's Avatar
    May 2016
    Northwest PA
    7
    What do you guys think? Can this pump be repaired?
    G
    17k Gallon 18'x34' IG liner, Hayward 1 HP Super Pump, Hayward DE Filter
    Jun 2014
    15,074
    Re: Is it time for a new pump?
    Hello G and welcome to TFP. Ummmm, there's no information in your post - other than the title. Were we supposed to see something else?
    GMil's Avatar
    May 2016
    Northwest PA
    7
    GMil's Avatar
    May 2016
    Northwest PA
    7
    Yeah. I don't know why the attachment to post originally. Rookie mistake. Thx!
    G
    Jun 2014
    15,074
    Ooooh. That looks pretty bad. I'd say sure, time for a new motor.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP! Add your pool info to your signature so we can better help you with your pool. More here, Pool School - Read This Before You Post
    GMil's Avatar
    May 2016
    Northwest PA
    7
    Thanks for the reply Texas! What would do something like this? I can't even get the bottom two bolts off the motor mounting plate they're so corroded which makes inspecting inside the motor impossible. Everything else seems to be in pretty decent shape (impeller, motor seal, etc. ) I'm fairly new to all this as we just installed the pool 4 years ago. It just seems like I shouldn't have to be dealing with something like this so soon.
    G
    Jun 2014
    15,074
    You might be better off referencing the motor's model number and Googling a replacement dry end, all the way up to the seal plate. Just start with a clean slate. That's my guess. We have some outstanding hydraulics folks on this site, so perhaps one of them will have another suggestion as well. Like Pooldv noted, now would be a good time to enter all of your pool equipment info into your signature next time you get a chance. It will help others reference a possible replacement motor for you. Depending upon the specifications of that rusted motor, we may be able to give you some better dry-end replacement options.
    GMil's Avatar
    May 2016
    Northwest PA
    7
    Thanks, here are some pics of the pump and motor model numbers in case anyone can add any more info. Until I can get some more time to see what I should be putting in my signature.
    G
    Jan 2012
    340
    Looks like your shaft seal has failed. Usually happens when the pump runs dry for a while due to low water, full skimmer, etc. After that happens, water is allowed out of the wet end and to the motor.
    Has the motor failed or is it noisy? If not, a rusty motor case is just that.
    If you'd like to replace the motor, you're looking for a 1hp round flange motor and PS-201 or equivalent shaft seal. Also will need housing and diffuser gaskets for Hayward Super Pump. Those pumps are pretty tough, so impeller, seal plate, and motor plate are typically reusable. Use an impact gun to get the corroded bolts out.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    GMil's Avatar
    May 2016
    Northwest PA
    7
    Hi pool man,
    Thanks for the great info. Yes, the motor has failed. It trips the breaker every time I attempted to turn it on and the impeller is jammed. I will try the impact gun idea but I don't like the idea of reusing old parts on a new motor unless I can 100% guarantee they are flawless. How would I verify the impeller has not failed also?
    G
    Jan 2012
    340
    I guess if you want to guarantee the parts you're using are 100% flawless, you should buy a complete new pump. Would be a good time to upgrade to two speed or VS.
    If your impeller has the brass threads and isn't broken or showing signs of wear it should be fine.
    Many people do multiple motor changes using original pump parts. It all depends how much you want to spend.
    GMil's Avatar
    May 2016
    Northwest PA
    7
    Good call. The impact gun pulled those suckers right out! Looks like I'm back on track to follow your advice and replace the dry end. What all is involved with upgrading to a VS motor? Does this require a whole new pump assembly? Will I need new wiring for the electrical?
    G
