Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: 2nd year opening first year becoming a tfpm
    Apr 2016
    Moundsville wv
    55
    Considering I adding an entire bucket of stabilizer last year because my pucks were eating up fast, I decided to pull my cover off, clean the surface and empty 2 feet of water. Now adding water to meet skimmer
    2015 built myself~15x30x52(15k)AG,vinyl liner~Hayward166t (16'' sand filter w1 Hp pump) Hayward sp1580 power-flo lx series~taylor2006 test kit
    Jun 2014
    15,192
    Re: 2nd year opening first year becoming a tfpm
    Hope your opening is going well this year. If you need help with anything or have chemical level questions, let us know. Have a good day.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,570
    Is it full yet? Have you turned your pump on yet? How does it look? Have you tested yet??
    Kim
    Apr 2016
    Moundsville wv
    55
    I have the last couple days. It rained the last 3 days so I took cover off, drained almost a foot below the skimmer, filled the water and back washed my new sand. I then swept and brushed surfaced and let the system run for 24 hours. My results are FC:2.5 cc:0 ph:7.6 Ta:110 Ch:200 cya:100 water temp is about 65 right now.
    Jul 2012
    Tallahassee, FL
    30,570
    That is some pretty water! Now get that FC up to match the still high CYA. Good job on draining it some. What are you plans for future draining?
    Kim (we have NO idea why some of the pics are doing that)
    Apr 2016
    Moundsville wv
    55
    Thanks it's been like that since I used the method the last owner was using but then after doing homework I realized I was all wrong and now it's all making sense. I have no clue either because it uploading right but then went upside down but before I dump any chemicals in it I was going to drain it under the skimmer and go from there. Hopefully that solves my issues I have picked up ten percent liquid chlorine for under 2 bucks cause of it being send to the wrong rdc but I don't wanna waste it to drain
    Apr 2016
    Moundsville wv
    55
    today< i drained my pool down to 2 ft and then refilled so i should let run for 24 and then retest?also, since im opening and restarting the whole system< should i add enough liquid chlorine as a shock level or just add enough to get me where i need to be depending on cya levels?
    Jul 2012
    Tallahassee, FL
    30,570
    You only have to let the pump run for about 30 mins or so before testing. I would brush the pool during that time to help mix it all in good.
    Test and add according to your test results. If you are worried about something being in your water you can do a OCLT (link below). This will show if anything is hiding and planning an ambush.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Kim
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Seems like from the picture, all the water would fall out and drain it self lol!
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Apr 2016
    Moundsville wv
    55
    i know right!i tried fixing it but it wouldn't exactly let me! today it was filled and i skimmed everything on the surface, swept and then brushed and back washed even tho i didnt really have to, its raining here and has been for days so i figured it would best best anyways!ill test in the morning and see where im at. thank you everyone, i ust admit its really nice to form a foundation here online then at a pool store. funny thing is most people that have pools have no idea and then come back 2 days later saying they have issues so, im bringing them to tfp
    Apr 2016
    Moundsville wv
    55
    Tested me water today after the drain and my results are fc:1 cc:0 ph: 7.4 Ta: 120 ch:170. So for now I'll up my chlorine to my cya 75 oz of 10% and let go over night to see if there is a lost and then go from there?
    Jun 2014
    15,192
    Drain and new water huh? Okay, then definitely refer to the Chlorine/CYA Chart (link below) to make sure you increase the FC to match your current CYA. That's very important. I would focus just on that issue for now. Good luck!
    Apr 2016
    Moundsville wv
    55
    After the drain my cya is now at 60! This was on Friday. Sat morning I tested for fc after bringing it to 6 and I lost nothing. Sat evening I had a loss of .2 fc at temp 70. I also added 3.8 oz of acid cause my ta was 130 it also brought my ph from 7.8 to 7.2 today I checked my fc was at 4.8 and ph was 7.2 with a ta of 120. I'm not sure how to aerate to bring ph up but considering a vinyl liner what ta should I aim for?
    Jun 2014
    15,192
    Once you use acid to lower pH more than normal to also lower TA, then aerating is best since it leaves the TA low. You can aerate by adjusting your return jets upward if possible, or make a DIY sprayer/fountain with PVC that many people have done which helps with aeration, cools the water in the summer, and is fun for the kiddos.
    Apr 2016
    Moundsville wv
    55
    I was planning on building a water jet for the kids to play in but wasn't going to do that until I finish the deck around the pool. Kids birthday party is coming in June so I opened the pool early just to get knowledge on the Bbb method and so far so good but it's just adjusting things that I'm getting use to! Would you think adjusting the eye ball up for a night would bring it up? I was thinking of testing for a week and then using my info to base how much chemicals I need per week and then testing weekly rather than daily. Once the temp goes up many things will change! Btw thanks for the quick response
    Jun 2014
    15,192
    How much pH rises in one night just depends on the amount of aeration. But give it a shot. If you need more later, try something like this: Pool water relief in an intex pool?
    Apr 2016
    Moundsville wv
    55
    i pointed my eyeball upwards which created bubbles and 2 hours later my ph was at 7.6. i saw on a similar post where it said to lower alkalinity by 20ppm which would lower mine to 110 that i would throw 4 gallons of acid (.16qts) into my pool that seems like a lot to me? any one you ever have a similar issue?
    Jul 2012
    Tallahassee, FL
    30,570
    STOP! FULL STOP! yikes! 4 GALLONS would bottom out your PH and could cause serious problems!
    Pool School - Lower Total Alkalinity
    You will lower it a step at a time. Use pool math to figure out how much MA to add to get your PH down to 7.2. Then aerate your water to push it back up to 7.8. Repeat as needed to get your TA down to about 70 or so.
    Kim
    Apr 2016
    Moundsville wv
    55
    i was thinking that was too much i actually did the acid demand test and then used the table circle on my test kit to determine how ma i needed to add. 70 is kind of low is"t it? i thought it was suppose to be around 80 to 120 ppm my fc has been pretty stable the last few days despite the loss of ph due to ma. i aerate the return jet for a half hour and im around a 7.6. also i scrubbed the entire pool after adding acid. how long do i wait upon swimming since i thru ma in?
  20. Back To Top    #20
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    I'd just use the Poolmath tool for your additions of MA to get a more accurate amount based on the volume of your pool. I just checked to go from 7.8 to 7.2 should take around 62oz of 31% MA. Maybe worth getting another reading on your TA. Should be right to swim about 1/2 after adding MA- just check that your pH is in range.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
