Results 1 to 7 of 7
Thread: Robot recommendation for a vinyl pool with a swim ledge and spill over spa?
    Aug 2015
    MI
    17
    I have a 36 x 20 inground vinyl pool with a swim ledge, with a eight person spillover spa next to the pool. The deepest part of the pool is 6 feet. I am looking for recommendations on a robot cleaner that will be able to clean the walls, the top of the swim ledge, stairs and be able to clean the spillover spa. I have lots of leaves in my backyard and also some acorns. I am a first-time pool owner and I am just figuring out the inns and outs of pools. We have about $1000 budget. Any advice would be greatly appreciated!
    James
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Robot recommendation for a vinyl pool with a swim ledge and spill over spa?
    I doubt any cleaner, robot or otherwise would be able to clean that size pool and be able to do the same for a spa connected by a spillover. Perhaps the pool and swim ledge but depends how deep the ledge is. If you could post more specifics about the depth of the swim ledge and perhaps a picture of the ledge area and spill over that would help.
    Isolated Spa - 345 Gallons
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I found a small Polaris P91 robot that I use just for my spa. I got it at Leslies a year or so ago on closeout. I use it during the winter when I get some leaves in the spa and the water is to cold for me to reach in to. You can find these things pretty cheap on ebay sometimes. I just throw it in and it might take 2 cycles but it gets everything out of the spa. I also used it for my backup if my Polaris 280 in the main pool broke down. (or once when my pump went).
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    Aug 2015
    MI
    17
    I'm guessing the swim ledge has about 10" of water over but I will measure when I get home. I'm attaching a picture of the pool, I'll try to add some other ones when I get home. It's hard to see from this picture but the ledge is directly across from the spa.
    But there's a chance I might need two robots?
    James
    Feb 2014
    Central Minnesota
    5,080
    If it were me I'd mostly be worried about having a robot for the pool that would have a shot at getting up on the ledge. Manually brushing/vacuuming the spa once or twice a week wouldn't be a big deal (for me). Do most of the leaves that land in the spa go over the spillway and into the pool? My spa is separate from my pool but when I need to vacuum it, I just use a piece of hose to get a gravity siphon going and suck the sand off the bottom.
    Aug 2015
    MI
    17
    Here are some pictures of my set up. The swim ledge is about 8" deep.image.jpg
    James
    Aug 2015
    MI
    17
    I've been doing research on these cleaners and my head is spinning. They all sound the same! My pool guy is recommending the Dolphin Supreme M500 for $1,1000. Any thoughts?
    James
