Thread: Help removing broken laterals
    Jan 2013
    Atlanta, GA
    13
    Hello, Im not sure how to move forward in replacing 2 broken laterals on my Hayward S244S sand filter (https://www.hayward-pool.com/pdf/man...210S-S244S.pdf). I removed all the sand and can access the laterals. They can rotate to face upwards and seems you can't just remove one but need to replace the whole lateral assembly. I tried to remove them from the elbow assembly but it wont move much and i'm not sure if the whole thing is glued in. There isn't much room to see or move around so i'm not sure how you would even remove the elbow if it was glued in.
    Does anyone have any tips? I don't want to break anything trying to get it free. Also it seems like the bottom of the Lateral Holder almost touches the bottom of the tank.
    Thanks
    Built 1994 25k IG plaster pool with waterfall spa, 1.5 HP Standard Motor - Full Rate , Hayward S244S Sand Filter
    Polaris 380 Pool Cleaner, TF-100 test kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Help removing broken laterals
    Those laterals look to be the type that snap into place, with central cone-shaped pins that snap into the lateral hub. You'll likely have to apply pressure to the side of the lateral to get one side to pop out. If the lateral is in the horizontal down position, you'll have to apply horizontal pressure. It would be easier if you can remove the lateral assembly from the inside of the filter. This means removing the elbow assemblies from the inside the filters by taking off the nuts labeled "18" on the diagram as well as the associated washers. The bottom elbow I believe is glued to the lateral hub but not the holder below. This of course means detaching the mutliport valve from the filter as well, just enough to get the '18' nuts off.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    Did you ever get these laterals out and replaced?
