Thread: Should I make any adjustments
    May 2015
    Kaplan louisiana
    69
    My test results are below, should I adjust anything? The pool is beautifully clear although we have got some severe weather the last couple of days so I decided to run my FC around shock level due to the water exchange I've been having because of the rain and having to backwash to waste.
    Fc 11
    Cc 0
    Cya 40
    Ta 50
    Ph 7.4
    Ch 50
    13500 gallon above ground with pentair sand dollar sand filter, 1.5hp pentair pump with TF-100 test kit. Kaplan, Louisiana
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Should I make any adjustments
    nope....go swimmin!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Looks pretty good! Just allow the FC to drop naturally and go ahead and go swimming!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yep, looks good. Good idea bumping up the chlorine for a bit to be on the safe side. I added a couple of gallons of bleach as the storms were passing through here on the way to you.
