Thread: Every morning my spa leaks about 2 inches of water
    Feb 2014
    East coast
    3
    My first post and I hope I am posting in the right forum.
    I have a spa pool combo and the leak in my spa have me baffled. Let me try to explain the situation. The spa has a spill over, when the timer shut the system down, the next morning the spa would have leaked about an inch.
    However, if before the system shuts down I use the valve and turn of the spa return, the next morning there would be no leak, not even a cup would have leaked. I don't know if it's the check valve that is bad or the spa return valve. Can someone help in this matter please.
    Thanks
    Hi, I have an elevated spa and pool, the pool is a 12000 gallons salt water pool and the spa is 750 gallons. It is an in-ground pool concrete with diamond bright finish. All Jandy equipment and pool was built and finish in June of 2009.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Every morning my spa leaks about 2 inches of water
    More than likely it is a leaking check valve. If you have the kind that can be serviced, they are fairly easy to replace.
    Mark
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by mas985 View Post
    +1
    Every time I've used my in-line puck chlorinator, my spa starts losing water overnight due to compromised innards on one of my check valves. I'm getting good at replacing them: Last time, the whole repair job took me about 3 minutes.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Feb 2014
    East coast
    3
    I want to thank both of you for replying, the problem was in my check valve like you mentioned. I was using some pool putty near the skimmer and I don't know how it happened but some of the putty was on the edge of the check valve flap, it was hard so I don't know how it got stuck there. After removing and replacing the check valve part it leak no more.
