Thread: Replacing pool pump - Question about Pentair union
    Feb 2015
    The Woodlands TX
    46
    As stated in the thread title, I am replacing an old single speed pump with a Pentair Superflo VS. The new pump came with a pair of union kits. So far, so good. The problem arose when I attempted to squeeze the union and a coupling into a short space instead of cutting the pipe in a better location and replacing the 90 degree elbow as well. When I cranked up the pump, the outflow side had a leak at the coupling joint with the union. Because I tried to squeeze it into a short space, I cut the union, and it is now no longer reusable.
    Leslie's has a union kit for $80! I bought a 2 inch female adapter at Home Depot instead. I won't know if it works until I cut off my mistake and install the new piping. I can get a union kit online for $37, and will arrive Tuesday.
    So, here is the conundrum. If I cut out the leaking joint and the female adapter doesn't fit, I cannot use the pump until Tuesday. (Even a leaky pump is of some value in filtering the pool temporarily.) If I order the part online, I have a leaky pump until Tuesday that I only would use sparingly. And, of course, a female adapter glued in would not allow removal of the pump without cutting pipe, though I am not sure how big a problem that is. The previous pump was glued in and never needed to be removed.
    Any advice? Preferences? I feel the safest route is to wait until the proper replacement part arrives, but I know there is always more than one way to accomplish these things.
    12,000, IG 1992, 4.5' center/3' each end, Pentair FNS-60 DE Filter (2015)
    PebbleSheen installed 2015
    Pentair Superflo VS installed May 2016
    TF-100 Test Kit
    Dolphin Nautilus Plus Robot
    Jan 2012
    340
    Re: Replacing pool pump - Question about Pentair union
    Wait for the union kit.
    I have never tried to screw a female threaded coupler onto a Superflo, so I don't know if it will work or not (although you have me curious now). What I do know is that you will be kicking yourself if you don't use the union kit and you develop a leak or need to pull pump for some reason.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Feb 2015
    The Woodlands TX
    46
    Thanks for confirming my suspicion. The more I thought about it, waiting 2 days for the part I KNOW will work was a much better option that taking a chance with an unknown. And, waiting 2 days to fix something right that will last for years seems like a no brainer. As I stated before, the pump is circulating and filtering the pool, even though there is a significant leak. I run it the bare minimum to keep the pool reasonably clean (Actually, since I also ran my Dolphin yesterday, the pool is very clean right now.) And the new part will be here tomorrow.
    Again, thanks for your response.
    TF-100 Test Kit
