Thread: Above ground pool Installation water issue at grade
    May 2015
    fairfield, nj
    19
    Hi everyone,
    just wanted to say great forum and information. I'm new and in the process of my above ground pool installation. I'm putting up a 15x33 oval pool and have just finished the rough level grade. The pics below show my house leader drain runs on the outside perimeter close to where the end wall will be. There is water run out saturation from the underground leader pipe which makes this corner soft and saturated. I have not had a heavy brain storm yet but am concerned with any effect this may have on the corner edge of the pool wall. I am located in new jersey and have cold winters. any thoughts on what action to take and if this will have an effect if not moved or re routed to another side of the property. Thanks
    Attachment 47320Attachment 47321
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Above ground pool Installation water issue at grade
    Welcome to TFP!
    Probably not helping much with a new idea, but I would eliminate that by all means to get it out of the equation.
    Essential Links:
    Casey's Avatar
    SW PA
    10,438
    Can you move the pool to the left at all? If so, you should do so!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    It looks like you have some big equipment there and that will make it easier, dig the old one up and dig a new trench away from the pool and install it there, you can make a sump pit at the end of it to help with dispersion, just dig down 4 feet or so and and 4 to 6 feet round and fill halfway with rock, end your new line over the middle and fill the rest of the way with dirt.
    Or you can do something like this with a pump Sump Basin Kansas City - KC Pro - Services the Kansas City Area
    May 2015
    fairfield, nj
    19
    thanks for the help, im moving the leader drain. Next question, im going with a 1 inch Extruded polystyrene bottom 4x8 sheets over leveled and compacted grade that i have in the picture. I will be gluing and taping the seems with tyvek tape. is there any other base i should add first below the polystyrene sheets or above before the pool liner? Most of my concern would be tree roots and im in new jersey so frost and heaving are also a consideration.
    Thanks
