Results 1 to 17 of 17
Thread: Is there another type of PH test - drop test?
    Aug 2015
    Teutpolis, IL
    45
    So I have a really hard time distinguishing the reds on the pH test. Hoping there is some other type of test out there I could do? Have a hard time with the yellow shadings on the chlorine test to and usually end up doing drop test unless in hurry then just look to see if tube fairly yellow or not.
    PH on the other hand there is no other test for it in the TF-100 test kit. I am always debating that our ph is 7.2 or 7.5 and hubby thinks it looks like 7.5 and 7.8 to him.
    I know color is so dependent on a person's eyes and what someone sees is different than the next so how do I know which is our correct number? At least with the chlorine drop test I am pretty confident when it has to go from red to clear. Is there a non color shading PH test somewhere that is accurate?
    18x33x4 oval Above ground pool- 15300 gallons, sand filter, full sun no shade
    tft-100 test kit
    Central Illinois
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is there another type of PH test - drop test?
    Not that I'm aware of Cheryl,
    I've always used digital meters for pH in my job, so it's been exceedingly hard to force myself to use this test. That said, I have gotten comfortable with it over time, and would encourage you to keep on with it. Decent meters can be had but IMO, the most dependable ones come in around $100 starting price. Some people have luck with the less expensive ones, but the results can be inconsistent meter to meter/brand to brand. With any meter, they need a fair amount of care and attention to keep them calibrated and accurate. Sorry I don't have a better answer for you.
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    13,191
    There is no other color pH test. You have a couple of options -
    1. Do the test in outdoor lighting with your back to the sun. Hold the test vial waist-high in the shade of your body and put a white piece of paper or a white paper plate on the ground. View the test vial with the plate as your background.
    Lighting and background color makes a huge difference to color perception.
    2. Try experimenting with one less drop (4 drops) or one extra drop (6 drops) of the R-0004. The test works as the number of drops determine the intensity or saturation of the color you see not the color itself. Some people find that using 4 drops works better.
    3. Get some R-0005/R-0006 acid/base demand reagents. These drops are normally used to determine how much acid or base you need to change the pH. They can be helpful in shifting the color of the sample by 0.2 units to help you confirm a pH value. They normally come as part of the Taylor K-2006 kit but are not included in the TF-100.
    4. Get a cheap pH meter and use that instead. They require manual care so that's something you have to factor in.
    Hope that helps,
    Matt
    Matt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I have better luck with the pH test if I hold it at arm's length and either squint or take off my glasses so it gets fuzzy. For some reason the shades are easier to differentiate when I can't see all the writing. If I'm between colors, usually I can tell if it's closer to 7.2 than 7.5, which means I can tell 7.3 from 7.4. I do the test outside, and use a white background, usually the cheap resin chair across the table from me.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I always hold mine up to a white painted post we have.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One other thing to keep in mind is you are looking for the tint, not the intensity, so keep in mind you are looking for the particularly shade of peach, not how bright it is.
    Aug 2015
    Teutpolis, IL
    45
    Thanks so much for the info. I always hold it to a white piece of paper I keep in my kit. I will try one drop more or one less. I am trying to look at color and not intensity but I can't seem to match. I can see the difference on the match part but then once I have my water colored I can't tell what it matches. Might try a cheap meter and try to compare it to my drop reading and between the too hopefully keep the pool in check.
    tft-100 test kit
    Central Illinois
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you do get a cheaper pH meter, make sure to read the calibration and storage instructions, you must always store it with the tip kept wet in storage solution and calibrate with calibration solution, either single or 2 point varieties.
    Jun 2007
    New Jersey
    653
    +1 on the acid/base demand reagents. I have the same problem with the reds. If I am high and up in the reds, I don't worry about what the exact pH is. I just add a drop of acid demand reagent. If it is then in the desired range, I know exactly how much acid to dose the pool with--it's a calculation you only need to do once. I have a container with a line marking the volume. If it takes two drops to get into normal color, then two doses. If one drop takes it to below normal range, then half a dose. Easy as pie. I've been doing it this way for over ten years.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Aug 2014
    NJ
    435
    Just to clarify. Can we use the r0005 acid demand test for the PH test that comes in the TF 100?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    May 2015
    13,191
    Quote Originally Posted by grottoguy View Post
    As long as the pH drops are R-0004 reagent AND the water sample size used in the test is 44mL, then the acid demand reagent will work with the Acid Demand chart.
    Matt
    Aug 2014
    NJ
    435
    Thanks. But The PH test that comes with the TF100 isn't 44 ml. Probably less than 10 ml. So where do you buy the one with 44 ml?
    May 2015
    13,191
    Which pH drops are you using, R-0004 or R-0014? Also, which comparator block are you using?
    Matt
    May 2015
    13,191
    OK, I see the problem here. The TF-100 comes with the Taylor K-1000 basic kit that has the 9781 midget comparator block and the R-0014 phenol red reagent.
    So, the acid demand drops that work with the R-0014 phenol red reagent are the R-0015 Acid demand and R-0016 Base demand reagents. You can NOT use the R-0005 acid demand drops with the R-0014 phenol red pH reagent.
    Matt
    Aug 2014
    NJ
    435
    Thanks joyful noise, I ordered the regent online cause tft didn't seem to carry that one. Can you point me to a chart that shows how to read the regent when used with my TFT ph test kit?
    May 2015
    13,191
    Unfortunately, the tables are printed in a booklet created and sold by Taylor Technologies called "Pool & Spa Water Chemistry" (HERE) which they sell for $7 (you can get one on Amazon). Because this is copyright material, it would be illegal for me to reprint the tables in any form and post them online. This is why Pool Math is designed with some advanced mathematical algorithms on the back-end so that you don't need acid-demand drops; you just enter all of your current water parameters in and it tells you how much acid to add to achieve a desired pH level while simultaneously taking into account your TA, borates, salt, etc.
    Anyone that buys a K-2006 gets the booklet and Taylor Watergram Dial (a nomogram for calculating SI) as part of the kit.
    Matt
    Aug 2014
    NJ
    435
    Thanks. I'm getting the acid demand drops as a backup to reading the ph color. If I'm not sure what color my ph is at I am hoping that by adding acid demand I will be at a color I can see more easily and then back into what my original PH was
