Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Taming the green beast
    Apr 2016
    Chardon, OH
    30
    You'll remember this photo from my equipment post:
    Nothing pretty here.
    I turned on the pump without the filter and let it circulate for a few hours. Initial numbers had the pH above 8.6 and TA around 80. I put in around 100oz of acid and got the pH down to 7.5. That didn't fit it. :P
    4/30/2016 2:00 PM
    FC 0
    CC 0
    pH 7.5
    TA 100
    CYA 0
    I added 4 gal 10% bleach and waited 15 min
    4/30/2016 2:15 PM
    FC 18
    CC 1
    More waiting and some backwashing
    4/30/2016 3:45 PM
    FC 12.5
    CC 1
    More waiting, more backwashing. Something is definitely happening in there. Many tadpoles lost their lives this day.
    4/30/2016 6:00 PM
    FC 11
    CC 1
    TA 80
    At this point, I need to add some water (from a well) to compensate for all the backwashing. I also don't want to stay up all night with this baby, so I decided to up the chlorine a bit, set the filter speed to medium and call it night. It's raining, if that matters.
    4/30/2016 9:45 PM Added 1.5 gal 10% bleach.
    22,000 gal L-Shaped Inground, vinyl lined, with diving board.
    IntelliFlo VS Pump, Triton TR100 Sand Filter, Intellichlor 40 SWG
    TF100 Test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Taming the green beast
    Welcome and good morning. I hope you had a good evening. One thing you might want to look at is scooping out as much solid stuff if you haven't already done that.
    Also what is your CYA number. I see you have it listed as 0. You need to have around 30 so the chlorine isn't eaten by the sun.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Keep them pictures coming! We love 'em! If you run out of space, open an account somewhere so you can link. Posting Photo's Tutorial
    This thread would be a good addition to Recovering my old inspirational links
    Vacuuming blind to remove any hidden debris will speed things up. It will speed up the filter clogging, too, but it has to come out sometime, and vacuuming helps mix the water.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You're on the right track, and it will just take some patience an Chlorine. I'd add enough Cya to get you to 30 PPM and just keep pouring the Bleach to it. Have you scooped the bottom for leaves and other debris that might be there?
    Essential Links:
    Apr 2016
    Chardon, OH
    30
    I haven't added any CYA yet, it is overcast and miserable, so I don't think the sun is much threat, but I will get it up to 30 today.
    I have been scooping and sweeping throughout. My back is killing me today. 600# of pebbles and sand might have contributed. But things are definitely looking better. I'll try to figure out the vacuum today too, I can tell there are 'deposits' on the bottom that disintegrate when the net touches them, maybe the vac will get it out.
    Here are the numbers from this morning.
    Should I be dealing with this pH? Or just let it ride until the SLAM is over?
    5/1/2016 8:20 AM
    FC 13
    CC 0.5
    pH 8.2
    TA 130
    TF100 Test kit
    Jun 2013
    South Florida
    118
    pH is reading high because your FC is above 10. If you set the pH before you started your SLAM, you are fine. Just continue the SLAM until you are done. pH reading will be accurate again one the FC drops below 10.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    that pool is already looking better keep going, you're doing great
    Apr 2016
    Chardon, OH
    30
    I didn't take another pic this morning because I thought it looked about the same, but in reviewing the pics here....It actually looks better than that now, so...sorry!
    But here's the numbers from this morning:
    FC 10
    CC 1.5
    I put in another gallon and a half to get it through the day (some people gotta work) and then gave it a quick brush down.
    Oh, and I wasn't able to deliver on the CYA yet. That stuff is REALLY stubborn to dissolve!
    TF100 Test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    Yep, that is why we recommend putting the CYA in a sock and hanging it in front of a return. More here on adding chemicals, Pool School - Recommended Pool Chemicals
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    This is gonna be awesome to watch but gotta ask...what in the world happened to that pretty fence?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Apr 2016
    Chardon, OH
    30
    A huge branch broke off the tree that used to be behind it in a storm. I took the rest of tree down. Now I need to order 1 new section of fence and a new mesh pool cover.
    Funny story actually - my mom came over to watch the kids so the wife and I could go out to dinner. She said "hey, you better take care of that dead tree before it falls on your pool" I said, yeah, but it's cold, I'll get it in the spring. Later that night she sent me a pic via text.
    TF100 Test kit
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Quote Originally Posted by PoolBoyDave View Post
    OUCH! Tell Mom not to mak anymore suggestions....
    Montgomery, AL
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Mom knows best! LOL Love you Mom!
    The color IS changing......you keep this up and you will start to see the blue coming out!
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I was going to ask if the beast from "Forbidden Planet" paid your pool a visit recently.
    Dolphin E10 Cleaning Robot.
    Apr 2016
    Chardon, OH
    30
    FC 13.5
    CC 1.5
    Added some more bleach to make it through the day and gave it a quick vac before work.
    And a pic from this morning
    TF100 Test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Nice work! Can't wait to see more.
    Apr 2016
    Chardon, OH
    30
    I stopped and got some liquid CYA on the way home yesterday, the powder is taking too long. There must be gold in that bottle from the $$$! I measured the FC @ 5 when I got home from work, so that isn't good, but we did have a fairly sunny day. (FC was 14 in the morning, and I added 1 gal 10%).
    Last night:
    FC 15.5
    CC 1.5
    TA 140
    CYA 25
    This morning:
    FC 14.5
    CC 1.5
    TA 240 (somethin ain't right, probably bad testing)
    So I think that means I am nearing the end of the SLAM. I added another 1.5g of 10% this morning because I don't have a handle on the daily loss yet. Still a bit concerned that the CC isn't dropping. The water is still cloudy, but the visible particles are way down.
    TF100 Test kit
    DFW, TX
    24,460
    Yes, liquid CYA is expensive, the granular is quite a bit cheaper. Be sure to wipe the tip of the TA reagent on a wet towel to release static and hold the bottle fully vertical.
    DontFillitin's Avatar
    May 2015
    Birmingham/AL
    377
    holy mangled fence! but that is going to be a beautiful pool!
    25,000 gallon IG with vinyl liner. Not sure how old it is. Sand filter, not sure what brand/size, Hayward Super Pump c48k2n143b1. I have a Polaris 180 cleaner on it's last wheel (haha). I'm still not sure about water restrictions, but haven't gotten any hate mail about the amt I used last summer. I absolutely LOVE my TF-100 test kit.
  20. Back To Top    #20
    Apr 2016
    Chardon, OH
    30
    This morning's numbers:
    FC 9.5
    CC 1.5
    TA 130
    CYA 30
    CH 150
    Seems to be using more Cl that it has been yesterday and last night. Rain related? I put in 2.5g of 10%, which should bring the FC up to 20. Hopefully that is enough to make it through the day. I also took a CH expecting to find it high on the account of well water top-offs, but it doesn't look bad. I can see about 18 inches into the water now, starting to get excited!
    Also - that CYA test is super subjective. I can change the ambient light and get any result I want...
    TF100 Test kit
