Thread: Replacing agp liner yourself
    Jun 2010
    Central Indiana
    92
    We have a leak in our pool. Losing 1-2 inches per day but have been unable to find the leak. We tried using the leak dye but not luck. Just put some "fix a leak" in it today and am hoping it fixes the leak(s) but if not may have to go with a new liner. Local pool stool said it cost around 2k for a new liner and installation and they couldn't do it until the end of June. I have found several liners online for $200 or less, so I can't see paying the pool store 1800$ more to install it. So some questions
    1) any tips on how to find the leak before we replace the liner? It's only 4-5 years old
    2) If liner does need replaced is it feasible to do it ourselves? any tips on what to buy and any advice or instructions on install.
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    Apr 2013
    Sacramento, CA
    2,769
    Re: Replacing agp liner yourself
    First go to pool school and read the section on leaks. Pool School - Leak Detection
    Next how about letting the pool drain down until it stops leaking. Then you will know about where the leak is. If it all leaks out its at the bottom.
    Have you triple checked the plumbing?
    Jun 2010
    Central Indiana
    92
    Thanks. I've read the leak detection article. It's definately not the plumbing. I let it drain past the plumbing and it kept leaking.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    We called around until we found a company that did it using some thingy LOL They put it in the pool and pulled it around the bottom. They had some kind of display that spiked when the thing in the water found the itty,bitty teensy, tiny pinprick hole. I got in with my mask on and patched it.
    Good luck....I wish I knew what it was they used. It was a while ago and I have forgotten what they said...I THINK it used a magnet but am not sure.
    Kim
