Thread: Opening Numbers and Slam
    Jul 2015
    PA
    14
    Opening numbers:
    CYA- 60
    PH- 7.4
    TA- 60
    FC- 0
    CC- 0
    CH- 120
    Noticeable algae blooms- beautiful murky pond color
    SLAM- added 307 Oz of 12% bleach for a target of 24 per pool math at 1:30pm
    3:15pm- 29 FC & 0.6 CC
    4:30pm- 27.4 FC & 0.4 CC
    15x30 Above ground of unknown origin. Hayward cartridge filter w/2HP Pump. Aquabot Rover Robotic Cleaner. BBB and Relax.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Opening Numbers and Slam
    Eat a couple Motrin in advance and grab the brush. You need to scrape off the slimy scab that algae grows to protect itself from the chlorine. One lap around the walls, then do the best you can do on the murky bottom, and then go
    Jun 2014
    15,186
    Jul 2015
    PA
    14
    Been scrubbing and keeping pain at bay with properly spaced beers. Getting some help from my robot doesn't hurt either.
    Seeing progress already
    Jul 2015
    PA
    14
    Quote Originally Posted by BMAN1029 View Post
    6:30- 26.4 FC & 0.4 CC
    I'm a little surprised that my CC isn't rising as FC is dropping and consuming those nasties. Not worrying about it yet though.
