Results 1 to 18 of 18
Thread: Starting again
    Apr 2016
    Poplarville, MS
    14
    Starting again
    So when I came to the forum and tested the water it was WAY off.
    So I drained about 70% of the water and it is filled back up thanks to some monsoon like storms and my well.
    So I am back testing the water and have some issues.
    FC=0
    CYA=50
    PH= SUPER LOW like a yellow. So I am guessing 6.6
    TA=?
    So I am doing the "High TA is anticipated" version of the test. adding 10ml water and 1 drop of r-0007 and 3 drops of r-0008. The instructions say Sample should turn green, well it doesn't. It turns red immediately. Anyone have any ideas?
    (so adding drops of r-0009 to turn it from green to red seems redundant, since it is already red
    I am really stopping her because I take it the PH and TA need to be addressed before I go on with any other actions.
    I am pretty stocked up on Borax, baking soda, bleach, Stabilizer, Muratic acid.
    And I am using the Poolcalculator site as well.
    Hardest time I have ever had getting the pool going!
    14,700 Gallon above ground Vinyl
    Sand Filter.
    Jun 2014
    15,159
    Re: Starting again
    Sounds like your pH and TA are incredibly low. I would start increasing the pH with the borax right away, shooting for the mid-7s. At the same time, consider adding some baking soda for an initial (low) target of 40 just so we don't go too high. Let that mix for about 15 min then check again. Adjust more as needed until you get the pH in the mid-7s and TA about 50-60.
    You also need bleach for sanitation and to prevent algae. At your CYA, you want your FC in the 5-7 range, never below 4. Start there and let us know things transprire over the next hour or so after a few 15 min tests and adjustments.
    FYI ... from a previous post./expert:
    If the TA test turns immediately red, then that means that the pH is 4.5 or below. Not good. Immediate addition of pH Up / Soda Ash / Arm & Hammer Washing Soda / Sodium Carbonate is required.
    PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice. Borax raises the PH and also raises the TA level just a little.
    Donldson's Avatar
    NW Ohio
    2,898
    Re: Starting again
    Your TA is zero, or even negative and needs addressed first. Calculate how much baking soda you need to get it to the 50-80 range and add that. Let it mix for an hour or two and retest your pH and TA. You will likely get readable results and can then fine tune your pH from there. Do this ASAP as your water is extremely acidic right now.
    EDIT: Looking back I told you to do this two weeks ago, did you?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    Quote Originally Posted by Donldson View Post
    Nope I drained the pool and only just started back working on it this weekend.
    How would I calculate how much baking soda to add if I don't even have a measurable reading on the test? 14,700 gallon pool. Do I assume it is starting at 4.5 or below as Texas Splash recommended?
    Sand Filter.
    Jun 2014
    15,159
    Re: Starting again
    Using the Poolmath Calculator, 104 ounces by weight of baking soda should increase your TA by 30 ppm. So you could consider doing it in stages like that until you start to see some indication of a normal test and color indications. Then you could get really specific and accurate. Thoughts?
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    I will give that a shot and report back! Thanks
    PS, does anyone know how to turn on E-mail notifications for posts that are responded to. I looked and cannot seem to find it, thus it takes me looking on here to see a response.
    Thanks to everyone, lots of helpful folks on here!
    Quote Originally Posted by Texas Splash View Post
    Sand Filter.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Starting again
    Look at the top of your first post on the right- "Thread Tools", under that is "Subscribe.." and then you can set those options.
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    Yal are life savers!
    So for whatever reason, my Free Chlorine is still testing 0 (Not turning pink at all when I put the r-08070 2 dippers in)
    *are the dippers smooth to the top or possibly overfilled? Just want to make sure I am not messing that test up
    So FC=0
    PH is not 7.4 (way better)
    TA=90 (good)
    but the other thing that is confusing me is that my CYA is stil testing 75. And that shows that I should replace 47% of the water. Remember, I just drained 70% and went back with that flood of rain and filling the rest from my well.
    *is cya "Stabalizer?
    Look forward to any suggestions.
    OH, and I do have algae so I am about to go home an Shock the mess out of it to get up to FC 21.
    Sand Filter.
    Jun 2014
    15,159
    Re: Starting again
    FYI - One gallon of regular 8.25% bleach will increase your FC by 5.5 ppm. Yes, CYA = stabilizer. If your CYA is 75, round it up to 80 and increase FC to SLAM level of 31. That's a little over 5 gallons of bleach. So I would get that going right away.
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    3 days after the SLAM the pool is looking blue, but still a little cloudy. I can say it has improved hour by hour! Due to my work schedule I literally only see it first thing in the morning. (the difference between yesterday at 7 am and today is remarkable)
    I took sample of the water and will test it today and get back on track with the "Regular" Pool math calculator.
    Sand Filter.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    Re: Starting again
    FYI you should test pool water pretty soon after taking a sample. Also noticed your earlier question, the 871 powder is a heaping scoop.
    Are you able to test and adjust at least 3 times per day?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    Quote Originally Posted by Mr Bruce View Post
    I am not able to test and adjust but 1 time a day. Except on Saturday.
    Thanks for the recommendation on testing quickly. I will do that now.
    Is the 871 power a heaping scoop?
    Sand Filter.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    Re: Starting again
    It's going to take a lot longer with only 1 visit a day. If that's all you can do then it is what it is; just be aware of the increased time and cost.
    Yes, the powder is a heaping scoop. Too much isn't bad (to a point) Too little is.
    What is your FC loss between tests?
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    10 AM test (After the Slam 2 days ago)
    FC=8.4
    PH=7
    TA=90
    Sand Filter.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    470
    Re: Starting again
    About the powder - just put in enough that the water turns pink. You don't have to use 2 dippers as long as it turns a good solid pink, not light pink. This is affected by your FC level of course - a low FC level will never turn dark pink, so use your judgement. Once you have the water balanced and establish a routine, you'll know that there is chlorine in the water and you can just use one scoop. If in doubt it is ok to put more powder.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    Re: Starting again
    I think you might be confused, a SLAM is not a one time addition of bleach. I recommend reading this page several times until it sinks in. Please ask any questions if something doesn't make sense. Pool School - SLAM - Shock Level And Maintain
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    FC=8.4
    PH=7
    TA=90
    I will start tracking my FC loss between tests. Thanks!
    Sand Filter.
    Apr 2016
    Poplarville, MS
    14
    Re: Starting again
    Got it! Thanks
    Sand Filter.
