Results 1 to 8 of 8
Thread: Best Robot for vinyl? Dolphin can't climb walls or slope!
    Jun 2015
    Duncan, OK
    17
    What robot cleaner do you guys use for a vinyl pool? I have a Dolphin Commander and it won't climb the walls or slope. So disappointed!
    New build, vinyl IG 18x40 3'4-9'
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Best Robot for vinyl? Dolphin can't climb walls or slope!
    I can't find your specfic model, but if it is older it may just need fresh treads
    Is your Dolphin Commander new, used, or heavily worn?
    If it is new, try adjusting the floats on the handle to a different position and see if that helps it climb better as well as leave it in the pool for about 15 minutes before actually starting it.
    If its not new, call 888-DOLPHIN for help troubleshooting the issue. I have a real deep end that has over 6 feet of full vertical wall which my Dolphin climbs just fine. In fact it climbs several inches above the water line to clean what would be the tile line above the water line in a concrete pool.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    Apr 2015
    Boston MA
    93
    Ditto... I just purchased a Dolphin Nautilus today and it will only climb the wall half way....any suggestions on how I can get it to climb the wall entirely to the water line?
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    Jun 2015
    Duncan, OK
    17
    Thank you for the replies. It's not new so I will definitely check the treads. Good luck derryank. I hope you figure it out.
    Apr 2015
    Boston MA
    93
    Thanks Shel...I'll try and keep you updated. Best of luck
    TF-100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    With the treads even if they don't look worn over time they stiffen, so if they don't feel soft and pliable you should try replacing them.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    My Dolphin Primal X3 does climb the walls. Not every time, but it's not supposed to. It comes to the top about every 5 minutes and does the water line. I love it!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
