Thread: 7.0 ph
    Johnmarkpainter's Avatar
    Apr 2016
    Hendersonville, TN
    55
    7.0 ph
    So I'm lowering my TA and bumped my PH down to 7 (am aerating).
    How long is it ok to have it that low?
    Oh yeah....
    PH 7
    FC 7
    TA 70
    CYA 70
    Salt 3600
    Borates 15 (haven't yet added but now might be a good time with the PH low?)
    (Lucky?)
    My sig
    28,000 Gallon, IG, Vinyl, SWG, Sand Filter
    Goldline Aqua Rite SWG
    Hayward Pro Series Sand Filter
    Flotec Pump
    Hayward Turbulent Flo Chamber
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: 7.0 ph
    7.0 should be no concern for equipment as that is by definition pH neutral. You have a vinyl liner so there is no danger to plaster or grout from a low CSI.
    If you are planning to borate using borax it will raise your TA when it raises the pH, so you don't gain by starting with low pH. If you are going to use boric acid it is pH neutral.
    chiefwej
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,490
    Re: 7.0 ph
    John,
    This is not a one step process.. You will need to check pH every three or four hours, and add more acid to bring the pH down again. Keep repeating until the TA is just below what you want. Then aerate until the pH comes up to 7.4 or so.
    For me anyway, the pH only stays at 7.0 for an hour before it starts coming back up. In three or four hours it will be back up to around 7.4.
    Apr 2016
    Hendersonville, TN
    55
    Re: 7.0 ph
    Thanks, all good to know.
    My kids are wanting to swim today....
    Flotec Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: 7.0 ph
    Quote Originally Posted by Johnmarkpainter View Post
    Let 'em. A bunch of kids splashing each other and using a kickboard will aerate that water big time.
