Results 1 to 7 of 7
Thread: Added Phosphate Remover to SWG
    Feb 2015
    Lake forest/ CA
    12
    Tested my pool and it was at 5 and ph was at 7.8 and cya was at 35. Still had an algae problem so I added some phosphate remover. Ran it for 24 hours and then checked and the chlorine jumped to 13. Does phosphate remover affect a SWG? Any other ideas? I turned off my SWG to get it back down to normal but can't figure out why it spiked. Thanks for any help.
    12k Gallon, IG, Plaster, Year Built 1988
    Pool and Spa (Spa waterfalls into pool)
    DE Filter (Pentair 2000 series 48), Hayward Tristar VS
    Pyrex triton mini max 400 heater
    Trouble free pool test kit
    30,419
    Re: Added Phosphate Remover to SWG
    Chlorine only increases in your pool if you add chlorine (in some form or another). I can't explain your jump othe4r than testing error or you added some chlorine and didn't realize it.
    Phosphate remover will not remove one iota of algae. nada...none.
    Chlorine is what kills algae and that's what you need in your pool now to kill it and then keep chlorine in your pool to prevent algae's return.
    You need to SLAM your pool
    read "The ABC's of Pool Water Chemistry" then read "SLAM" in Pool School
    Feb 2015
    Lake forest/ CA
    12
    Thanks. I thought it would work. Strange it spiked up so high. I was wondering if the salt cell went a little crazy but that still seemed weird. slam it is.
    Apr 2013
    Sacramento, CA
    2,769
    Did you test again an hour latter? When I get results that don't make sense to me I either test again after an hour or call in my 11 year old daughter to run the test again.
    And as Dave said phosphate remover won't kill algae.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Phosphate remover will make your grids all nasty !!!
    And drain mony from you wallet !!
    Looks like that CYA of 35 might be the real issue ..
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Dec 2014
    Sydney, Australia
    43
    Quote Originally Posted by uwquigman View Post
    How long do you 'normally' run it for if its 6-8 hours and you have run it for 24 there is your answer...
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Quigman, what brand of phosphate remover did you use? Usually, its comprised of lanthanum chloride, and in some cases a clarifier. Maybe the extra chloride improved function, or the clarifier had some other kind of impact on your cell. Just wild guesses here Unfortunately there does not seem to be a lot of data points on the dark art of phosphate removal.
    Either way, bumping up the cya per the recommendations for swg in pool school should help you avoid getting algae in the first place.
    (After your slam, that is.)
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
