Thread: Multiport Interchangeability
    Apr 2016
    Helotes Texas
    2
    I just ordered and received a new Pentair multiport valve replacement (pn261152). I think I should have ordered pn261050, but I don't see any reason why I cannot use the one I received. Yes, it has threaded connections which will require three threaded PVC connectors. It is the pressure side, so leaks should be obvious.
    My real concern is the connection from the pump outputmto the valve. It is side mounted, unlike my original that connects via the bottom. Again, I do not see any problems other than new PVC connectors and a short riser piece on the pump output to achieve the new level.
    Am I missing something, or will this substitution be OK?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Multiport Interchangeability
    The only thing I would worry about is whether or not those threads are standard pipe threads or some kind of proprietary pentair thread for a coupler.
    Apr 2016
    Helotes Texas
    2
    I checked with a Sched40 2" PVC threaded coupler and it fits fine. I will, of course, use Teflon tape.
