Thread: Should I increase TA?
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    My water has been extremely stable for the past 2 months with this morning's test being the norm. I am losing 1 FC consistently per day & the PH creeps up about .2 weekly. I am currently targeting a PH of 7.2 - 7.6.
    I have a little bit of staining / tough buildup in some areas & I am keeping PH on the low side of normal to help combat this along with brushing.
    My question is, should I raise the Total Alkalinity or am I OK with it hanging out at 60?
    FC-5
    CC-0
    CH-250
    TA-60
    CYA-50
    Borate-50
    Port Orange Florida
    In Ground Plaster Kidney
    36 x 18 - 16,000 Gallons. 3ft - 6ft
    Hayward C12002 Cartridge Filter, 1-1/2 HP Pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Should I increase TA?
    60 is fine. I keep mine between 50 & 60. If I don't pH rises much too fast for my liking.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Rather than raise TA, why not let the pH hang out at the higher end? Say, 7.6>7.8. Your CSI is pretty low if you knock the pH down to 7.2.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Numbers looks good i'm keeping mines at 50 with PH stable at 7.6
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    I am holding th PH down for a few weeks while trying to brush off some brown streaks. Inherited a pool with a lot of gritty buildup & I am knocking down the last few streaks. Seems I read here that a lower PH can help with that. The pool likes to hang at a PH of 7.5-7.6
    Port Orange Florida
