Results 1 to 7 of 7
Thread: Bleed filter thingy...
    Feb 2014
    Leander, TX
    33
    Question Bleed filter thingy...
    Anyone know where/how to buy "JUST" the thing circled in this image?
    It keeps getting damaged/compresses/crumples and I need to replace it.
    Thanks!
    23k gal IG pebble, 48 sq ft Pentair FNS Plus DE filter (FNSP 48) 96 GPM, 1.5 HP WhisperFlo pump, Kreepy Krauly Legend Robot.
    Pool was built in 2011, in Central Texas (Leander, TX)
    Jul 2015
    Central Valley CA
    1,109
    Re: Bleed filter thingy...
    do a google search for "pool filter breather tube" or pool filter breather tube assembly.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2014
    Leander, TX
    33
    I tried that. I was just looking for the mesh piece at the end. I tried to buy it before, but apparently it wasn't the right type/size, so I was wondering if there was a place I wasn't aware of to get just that piece. If not, I'll buy the tube thingy, too....just seems like $15 for that stuff is steep if I'm replacing it a few times/year.
    Feb 2011
    Petaluma, Ca
    665
    I have had the same one for 5 years, why does it matter if it has a few dents, as long as there are not holes.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Feb 2014
    Leander, TX
    33
    The dent corners turn in to holes, so I thought it was effecting the performance...
    Jul 2012
    Dallas, TX
    179
    Pentair P/N Pentair 172855
    Amazon link
    Amazon price isn't the lowest. I use Sunplay for a lot of my pool parts.
    Sunplay link
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Feb 2014
    Leander, TX
    33
    Thanks Scoop! Unfortunately, I ordered that same part off Amazon last year and had to return it because it doesn't fit the same I think the only way to find just the vent thing is to order the assembly Thanks for the sunplay link, that's what I need!!
