Thread: App for PoolMath
    Mar 2016
    Houston, TX
    27
    App for PoolMath
    Is there a good app to track pool math info?
    Bill
    The Woodlands, TX
    in-ground plaster pool, hot tub overflow to pool (16,000 gallons), 48 sq ft Nautilus FNS DE filter, gas heater, dual main drains pool & hot tub, chlorine source bleach (10%) & trichlor tablets 2-3 times/yr, Taylor K-2006 kit, 55-60 gallons per minute flow
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: App for PoolMath
    I just use Pool Math directly on my iPhone & iPad. It works in Safari so there are no issues.
    There are a couple of apps out there that some folks use. I will caution you that they are independent of TFP ans should we make changes to Pool Math they may not be reflected in those other products.
    Support the site
    Mar 2016
    Houston, TX
    27
    Thanks for the tip. Do you keep a written log of your test results?
    Bill
    The Woodlands, TX
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by wjthomas42 View Post
    I did for a while, but once I got my CYA in line it's a lot of sameness.....
    I have a Stenner pump,that automatically adds bleach as the pump runs. With the floods South Carolina had this year my CYA was way down so I'm floating tabs in addition to the bleach. The acidity of the tabs is holding down my pH rise so to be honest my pool is on autopilot right now.
    It takes a few months of testing and learning your pool but eventually you will understand it's particular movements.
    Support the site
