Results 1 to 9 of 9
Thread: How to find out where the cable has no continuity if cutting the pool vac cable
    Apr 2015
    Nashville
    40
    I have a pool vac and the electrical cable to the vac has no continuity. I had this problem before and they cut a part of the cable and reconnect it to the unit. If I am to cut the cable the then hook it back to the unit. How will I know where the cable is kinda 'broken' at that side? Thanks. It is a Aquabot Turbo T. Unit ok as I had serviced it last year but the cable has a problem.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    Re: How to find out where the cable has no continuity if cutting the pool vac cable
    Phillip,
    Logic says that cables generally do not break in the middle. Since this is a robot, my guess would be the cable is broken right at the end going into the robot. It could also be broken at the power supply end if you have been constantly connecting and disconnecting that end of the cable.
    Nov 2015
    Carrollton tx
    451
    jiggle it ?
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a Badu® Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by Jimrahbe View Post
    Phillip,
    My thoughts as well. Anywhere the cable makes a tight bend is a good candidate, especially if it also flexes in the same area, like right where the cable enters the housing.
    Apr 2015
    Nashville
    40
    Phillip,
    Thanks a lot..I* will check it out
    Apr 2015
    Nashville
    40
    if I cut the end of the cable.. then how do I reconnect it back to the 3 pin plug? it will be underwater possibly.
    Jul 2014
    Bedford, TX
    7,520
    Sorry, I'm not sure how your robot is internally connected. On the older Dolphin's they have a kit you can buy which has the rubber seals and new pins for the internal connector. You might want to use Google and see if the Aquabot has the same set up..
    I would not cut anything until I opened it up and saw how it was connected inside the robot first.
    22,551
    Go rent a Time Domain Reflectometer and run a test on the cable. It will tell you exactly where it's broken. However time you do that you could buy several new cleaners!
    The best advice is to slowly bend the cord near the strain reliefs, and see if you can determine where it's broken.
    You'll most likely have to replace the plug because they're usually molded on.
    Jul 2014
    Bedford, TX
    7,520
    Dave,
    If the OP knew how to use a TDR, I doubt he would have had to ask his original question.
