Thread: Question: Pool just resurfaced with WetEdge Luna Quartz, Lots of Streaking, Footprint
    Hi,
    My 2 week startup specified by the PB just finished and so the pump is not running 24/7. Now I see a lot of large streaking, footprints, etc. Emailed PB this morning. Would like to get feedback from the forum - I don't think this looks acceptable based on other posts, but wanted the forum's opinion.
    David
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Question: Pool just resurfaced with WetEdge Luna Quartz, Lots of Streaking, Footp
    This is something best left to between you and your PB. All we can tell you is that yes I see the color differences. It is up to your PB as to what he can/will do for them.
    Good luck!
    Kim
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    This is my fear about plaster too. The warranty doxument I was provided by my PB says that mottling and uneven looks are to be expected. That being said, so many pools have darker colors without mottling. Not sure if it only the applicator skill involved or is there anything more than that.
    From my review of posts in TFP, streaking far worse than what you have has been corrected using a variety of methods. As Kim pointed out, you should be able to work it out with your PB.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    See if this helps to figure it out, Diagnosing Pool Plaster Problems
