Results 1 to 10 of 10
Thread: Too much pressure blowing DE grids
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Pool store says my pump is putting out too much pressure. I have blown 3 grids i am running 18 lb on my gage ( pentair whisperflo 1.5 hp.) ( hayward DE 60 Pro filter) Has anyone had this problem and how to correct it? Should restrict the flow?
    Walt Lukowski
    Southern California
    Salt water pool at 24000 gal. new whisperflo variable speed pump. 60 gal. per min.
    37,399
    Re: Too much pressure blowing DE grids
    Pool equipment, like filters are designed for 50 psi. So there is no reason they would "blow". In reality, the water flows from outside to inside, so they would get crushed.
    Pictures of the damage?
    Jan 2012
    340
    How old are the grids? They are not made of anything special and wear and tear/chlorine breaks them down.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Quote Originally Posted by wbrewski View Post
    I will take a couple of pictures and post them.
    Hole 2 Photo by wbrewski1 | Photobucket
    Walt Lukowski
    Southern California
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    I have exactly the same filter and until I added a VS pump, my system ran for ten years at a filter pressure of around 30psi. The filter is rated for 50psi.
    chiefwej
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    I have added a photo.
    and thanks for the help, I guess the pool store employee does not new his stuff
    Walt Lukowski
    Southern California
    Even though the Maximum Working Pressure is listed as 50 psi, it’s not a good idea to run anywhere near that pressure. System components are more likely to leak or fail prematurely.
    Also, 50 psi does not tell the whole story. What matters to the integrity of the grids is the pressure differential between the input to the filter and the output of the filter. For example, if a system were 70 feet below a pool, it would add 30 psi to the system, but it would not add any stress to the grids, because the pressure on both sides of the fabric is increased by 30 psi.
    In other words, it matters if the pressure is created by the grids or by something after the filter.
    At about a sustained 30 psi differential, the grids will begin to collapse and you will get tears at the spot you show because that spot does not have good support.
    The Whisperflo is a high head pump and can get up to almost 39 psi. It can definitely damage grids if the pressure is caused by dirty grids.
    It would be better to reduce the power of the pump, if possible/practical. If not practical, then keeping the grids very clean would help reduce damage.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    Instead of blowing holes in the cover material, I would have expected it to first crush the internal structure of the grid. But James is right in that pressure differential due to dirty grids, not just high pressure alone is what would cause damage to the grids.
    chiefwej
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Thanks for all the feedback. I will watch the pressure more closely, and backwash more often.
    Walt Lukowski
    Southern California
    37,399
    We recommend backwashing when the pressure rises 20-25% over the clean pressure. And you should do a full tear down and cleaning at least once a year.
