Thread: Confused about wiring the GL-235 solar controller up for timer overide
    Apr 2015
    Houston Ohio
    148
    Hello all,
    I just purchased the GL-235 and am very confused about wiring the system up for the timer override. Haywards drawings don't make sense to me. I cant tell whether wires are tied together or bypassing.......THanks in advance.
    https://www.hayward-pool.com/pdf/man...olarGL-235.pdf
    Figure 3. Page 8.
    I have this timer with a non-varying pump.
    Intermatic T104 Heavy Duty Timer DPST For 240V Load - 240V Clock
    http://site.electricsuppliesonline.c...ng-diagram.jpg..
    36k gallon in ground, Hayward 30in sand filter, 2hp Hayward pump, in-line chlorinator. Vinyl from Ohio.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Confused about wiring the GL-235 solar controller up for timer overide
    Either I'm missing something or me thinks the Hayward drawing has an error. I would call customer service have them explain it.
    I know waht I would do but I would rather have their customer service line explain it to you.
    Apr 2015
    Houston Ohio
    148
    I'll call, but feel free to give your input
    Apr 2015
    Houston Ohio
    148
    So I think I have it figured out. I color coded the diagram to make it easier to understand (in my mind anyways).
    So will it burn up the pump having one hot 120v leg running to it all the time?
    sorry, I don't have Visio at the house.
    Apr 2015
    Houston Ohio
    148
    Cut power to half of 240v
    250 volt Swimming Pool Disconnect Switch - YouTube
    Im not so much worried about the electrical hazards because I have a double pool switch with fuses on the front side of this.
    Apr 2015
    Houston Ohio
    148
    This is the final wiring schematic.
    The chlorine pump is still controlled by the timer.
    The shed fan still kicks on anytime the pump is running, which is ideal. Whole purpose of the fan is to ensure the pump doesn't overheat in the shed.
