OK. Lowes or Home Depot for muriatic acid. Found it.
Why am I dropping to pH 7.2?
Because pH will rise over time but you won't be able to test it accurately at SLAM level chlorine. So you get it low up front and hope it doesn't get too high while you're unable to test it. Also, bleach works better at lower pH.OK. Lowes or Home Depot for muriatic acid. Found it.
Alright. Thanks guys. I will get on it tomorrow. How long will my chlorine stay high?
So call it a night and reread it tomorrow when you're feeling fresh.Thanks for the link. Getting a little overwhelmed after reading that.
Yes. Until you pass all three tests at the same time: clear water, .5 or less CC, overnight loss less than 1 FC.Just rechecked and FC is now 9 and CC is 0. Should I bump back up to 20 FC?
