Thread: Intex Krystal Clear Sand Pump's gauge is always in the red. Broken?
    Apr 2016
    East Tn
    6
    Hey all,
    this is our second season using our Intex sand pump. It's an awesome pump and is still working great! We are on day 2 of the swim season this year. I noticed today that the gauge does not move. It's consistently at about 55psi which seems very high and is way in the red. But the pump is working great. Excellent, strong return. I backwashed and rinsed it today. Last summer when the psi would get high, I'd do that and it would go down. Doesn't seem to make a difference this year. Is my gauge broken? Needs more sand? Any ideas?
    My pump is 2800gph
    My pool is a Coleman 18'
    I am using a skimmer that I installed after purchase and all Intex hoses/plunger valves
    TIA
    Jun 2014
    15,298
    Re: Intex Krystal Clear Sand Pump's gauge is always in the red. Broken?
    Amanda, it's very possible your gauge just needs to be replaced. It happens. Better than replacing the whole pump/filter. I think on those pumps the gauge is mounted on the side and can be replaced. Should be an easy DIY item. You can order a replacement gauge from here at the TFTestkits.net page if you like. They are good quality and have it shipped to your front door. Just a thought. Have a nice weekend.
    Apr 2016
    East Tn
    6
    Yes, the gauge just mounts on the side near the top. Replacing it would be ideal since the pump still appears to be working great! How do I know which gauge I need? The rear mount?
    Jun 2014
    15,298
    Rear mount looks like it should do the trick. Just look closely at the back of your current gauze to make sure it looks like it has a threaded male end that goes into the pump housing.
