Thread: New Test
    New Test
    I have the TF test kit and have used it for years- however I basically have been using the Chlorine drop test every night to determine FC/CC- I just noticed it said to do that test weekly and do the daily test (K-1000) for Chlorine and PH..I do use the K-1000 for PH but I don't understand how to read it for Chlorine...No issue with pool water has been crystal clear since we converted from Baqua about 7 years ago.....Can some one explain the Chlorine test- I just did mine and the yellow matches up with the 3-6 color window? My CYA is at 30-40 and I maintain per the CYA chart-
    Thanks
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: New Test
    The 3 is chlorine and the 6 is bromine. Two different scales. It doesn't sound like you add bromine to your pool. What about the FAS/DPD chlorine test? That is the precision chlorine test.
    Here are videos for the tests
    https://www.youtube.com/user/tf100te...e=results_main
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: New Test
    The colormatching chlorine test is more of a sanity check. Unlike the pink DPD chlorine test, the yellow OTO test will not bleach out.
    I use it quite a bit, but that's because I already can predict my readings with amazing accuracy after several years of testing and dosing. I know if the color is at least as deep as the highest sample, I'm good, and I can just go ahead and add the usual amount.
