Thread: Staining from Copper and Chlorine Shock
    Apr 2016
    Fort Myers, Florida
    2
    Several months ago I noticed black stains on the bottom and sides of my pool within hours of putting in Leslie's Power Powder. The pool was tested and showed some copper but no other metals. I Used Leslie's metal eliminator package (Stain Remover, Metal Free and Metal Curalotor packet) once the pool's chlorine level was less than .5 ppm as instructed. It has been several weeks with minimal change and the minute I again added Power Powder to re-chlorinate the pool the black spots began increasing. I found a post by onBalance, Senior Member and TPF Expert from 1-15-13 for a similar situation and he recommended using "potassium alum" granular (2-3 pounds) to remove the black stains quickly and vacuuming to remove waste and residue.
    My pool is a 10,000 gallon, gunite, in-ground pool with a Haward filter and chlorinator. I have the following questions:
    1. How much potassium alum should I use for a 10,000 gal pool?
    2. How is it applied? Filter on or filter off?
    3. What should the chlorine level be when I add the potassium alum?
    4. Where can I purchase potassium alum granular.
    5. Are there any precautions I need to take when using this chemical?
    My pool is a 10,000 gallon gunite in-ground pool using a Hayward filter and in-line chlorinator.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Staining from Copper and Chlorine Shock
    I'd be interested in knowing what your PH level is. Sequestrants are not a one time shot either. They have to be replenished as needed.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Usually, after you do a stain treatment, you should raise the chlorine level very slowly. It's recommended that you use only bleach or liquid chlorine. Should never use powdered unless you need the extras that come with it. Stuff like CYA or calcium. Here are a few links about it.
    Pool School - Metals in the Water and Metal Stains
    Ascorbic Treatment to rid Pool of metal stains
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2016
    Fort Myers, Florida
    2
    Quote Originally Posted by woodyp View Post
    PH is 7.4
